01-25-2011, 10:27 PM | #1 |
1967 C/20 4x4 3 on the tree 292 project
Here there I was trying to figure out if taking out the 292 a 3 speed out of the 3/4 4x4 and putting in a 1990 350 5.7 and tranny out of a body beaten scottsdale. Will that swap even work. I plan on re-wiring the truck and a under bed fuel tank. I plan to make this a frame off restoration. and using this truck as a daily driver.
01-26-2011, 06:59 AM | #2 |
Re: 1967 C/20 4x4 3 on the tree 292 project
Yes,you can do that. You'll need all the wiring and ECM. The '90 had an electronic speedo so that will need to be dealt with.
Just a note...get used to calling your truck a K/20. That's what Chevy called the 3/4t 4wd.
01-26-2011, 07:25 AM | #3 |
Watch out for your cornhole !
Just FYI, I don't believe that's a 292 engine. It's hard to tell from the pictures, but I can't see the bypass hose that only 292s had. Likely it's a 250 that's been swapped in.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-26-2011 at 07:26 AM. |
01-26-2011, 10:40 AM | #4 |
i could be wrong but it looks like you've got power steering? if so you could cover some of the cost of the swap(if u arnt keeping motor) as the power steering set ups for sixes are hard to come by and many people would love to get their hands on it.
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l |
01-26-2011, 11:16 AM | #5 |
not to many lwb steppers
01-26-2011, 11:35 AM | #6 |
Vintage 4x4s
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
01-26-2011, 08:05 PM | #7 |
Thanks for the Info guys. as far as the drive shafts, will i most likely have to get custom ones or will they be able to stay. as i hear that if a manual is changed to a auto in some cases it would have to swapped?
01-26-2011, 08:39 PM | #8 |
Does the motor have tall push rod covers on the pass side or short covers ? big ones 292, short ones 250 !
01-26-2011, 11:56 PM | #9 |
If your interested in starting a build thread there is a 4X4 projects and builds section. It looks like it would be a great build to follow.
http://67-72chevytrucks.com/vboard/f...play.php?f=141
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
01-26-2011, 11:58 PM | #10 |
i like the spotlight on it we need interior shots
01-27-2011, 01:01 AM | #11 |
It's hard to say on the driveshafts since that combo isn't from these trucks. It's not a big deal or real expensive if shafts do need altered.
How about posting some pictures here...http://67-72chevytrucks.com/vboard/s...d.php?t=441713
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 01-27-2011 at 01:03 AM. |
01-27-2011, 08:53 PM | #12 |
OK what about swapping bodys put the 67 body and box on a 1990 frame it would make everything on the truck updated there both longbox single cab so is that possible
