Old 01-29-2011, 11:44 PM   #1
cww1967
1972 super cheyenne knocking 454
i was told it is a 454 but could be bb 400 anyways the timing is at of whack #1 at #8 cynd. but any how top end was rebuilt so the say if the timing is really out of whack and if the lifters are to tight could this cause a knock and heavy black/gray smoke any thoughs thanks Mark,
cww1967 is offline   Reply With Quote
Old 02-10-2011, 12:56 AM   #2
dan42
dan42's Avatar
Re: 1972 super cheyenne knocking 454
You're gonna need a little more info than that - get the plug wires and timing straightened out first, then you'll have a better idea -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 02-10-2011, 01:45 AM   #3
vectorit
What?
vectorit's Avatar
Timing out, can cause a nasty spark knock. Combined with a poor performing carburetor, the engine could be lean or rich. Rich mixtures will cause a sooty exhaust, and a noxious exhaust that will make your eyes water and give you a head ache in short time.
Tight valves in my experience can cause back fires out the carb, and or a rough idle.
Engine cubes don't matter if the ignition timing is incorrect, and the intake/exhaust valves are miss adjusted. No matter what size, it's gonna run badly.
Like noted above, get all that tuned and adjusted correctly asap.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
