Old 02-02-2011, 02:43 PM   #1
john rod
alignment ?'s
i just replaced all the front end parts on my '67 C-10 panel [2wd].
took it to the new tire store, with a new rack. the toe-in is my problem.
the computer print out shows the front toe-in in degrees and the counter guy had no idea what that meant in inches.
so anyone have any idea what .19 degrees [per wheel] or total of .38 degrees toe-in means?
thanks rod in [cold]AZ
john rod is offline   Reply With Quote
Old 02-03-2011, 10:59 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: alignment ?'s
hey... the boards from NC john rod!!!
may want to shoot member 'cparman' a quick message to see if he can help ya out....or I'm sure someone may chimp in here shortly!!!
as a side note, I originally took my truck to a new tire store, but the kids in there didn't have a clue what to do because my year truck wasn't in the computer!!!....So I took my truck to a place that a local hot rod shop uses often (just called them and asked 'where's the old cat in town that does alignments for your hot rods???)....he does it manually and is chalk full of good ol' stories...and did a heck of a job for $60!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-03-2011, 04:13 PM   #3
72MARIO
72MARIO's Avatar
Re: alignment ?'s
I think that was about 1/8 "
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-03-2011, 06:24 PM   #4
463
463's Avatar
Re: alignment ?'s
1/8" = 0.348 degrees (total, so 0.174 degrees per side) sounds close. some drivers will hand the # they want to the tech
Trueman
463 is offline   Reply With Quote
Old 02-03-2011, 09:36 PM   #5
Heavy Evy
born to lose
Heavy Evy's Avatar
Re: alignment ?'s
If you plan on messing with the frontend some more or keeping the rig for a long time Do yourself a favor and take it to firestone and get a lifetime alignment. There only $130-160ish. You pay once and bring it back whenever you want to get it rechecked its also good at all firestone locations nationwide.
_____________________
'67 Chevy Belair Wagon 283 Powerglide
'68 Chevy II Nova 2 door 350 TH400 Sold!!
'71 Chevy C20 350 TH350
'71 Chevy C10 Burb 350 TH350 stolen totalled gone....
Burb Build
http://67-72chevytrucks.com/vboard/s...d.php?t=475155
Nova Build
http://67-72chevytrucks.com/vboard/s...d.php?t=498979
Wagon Build
http://67-72chevytrucks.com/vboard/s...d.php?t=543052
Not giving a truck.
Heavy Evy is offline   Reply With Quote
Old 02-03-2011, 10:07 PM   #6
cparman
sharp as a marble
Re: alignment ?'s
Well the old man read this, and Damnit! I don't have an answer! BUT, I will tomorrow night. I do not like the degree thing. I have a note posted on my alignment machine that converts degrees to inches. IF the old man remembers he will post a chart here tomorrow night. Like GCBURBIC said, you need to find a traditional shop that does alignments near you. The younguns at the tire stores are lost when it comes to our stuff. Here is the world according to me:
Camber 0 degrees
caster as much as you can get positive
Toe 1/8" in
On our trucks caster is a challenge. I try to get the camber and toe where I want it, and then fiddle around trying to get the caster to be a bit .5 degrees more positive in the right wheel. If you can do this it will help with a pull issue. All roads in our great country have a crown to them in the center. If you have a bit more positive caster in the right wheel it will allow the truck to track straight. It has always been my belief that the responsibility of the alignment guy to give you good tire wear first and tracking stability second ( caster).
We aligned a 2002 Porsche 911 C-4 today. The car had 45k on it and was on it THIRD set of tires!! The owner is a 65ish yr old guy. I told him that we were going to align this car MY WAY. The factory setting for the rear of the car was -1.5 camber, and 0" toe. What we found was -1.8 camber, and -13" toe. I ended up with -1.2 camber and 0" toe. What this means to you is that it SHOULD add tire life to this car. We also sold him a set of tires. His bill was $1100. I think I saved him money
cparman is offline   Reply With Quote
Old 02-03-2011, 10:09 PM   #7
cparman
sharp as a marble
Re: alignment ?'s
OH YEA, Thanks for the PROPS GCBURBIC.
Old 02-04-2011, 11:38 AM   #8
john rod
Re: alignment ?'s
thanks all, I will wait to see if there is a post of a conversion from degrees to inches.
there are only five racks in town and all are the same. ugh. there is no choice!
rod in AZ
Old 02-04-2011, 02:55 PM   #9
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: alignment ?'s
Just googled this stuff...maybe cparman will have something else...
http://www.smartracingproducts.com/p...e_settings.pdf
Geoff with a G
Old 02-04-2011, 10:54 PM   #10
john rod
Re: alignment ?'s
the chart showed me exactly what i thought. with .39 degrees [total toe-in] and a 27" tire, the total toe -in is close to 3/16". way toooooo much. going to see the guy in the morning! will try to hold the old temper in.
rod in AZ
