Old 02-04-2011, 10:09 PM   #1
How the heck does the grill attach, 76 GMC *revisited*
I must be missing some brackets the grill screws onto?
Old 02-04-2011, 10:35 PM   #2
76stepsidechevy
Re: How the heck does the grill attach, 76 GMC
Theres two stamped steel brackets that are probably missing if your truck had and aftermarket grill on it.
76stepsidechevy is offline   Reply With Quote
Old 02-05-2011, 09:49 AM   #3
Thanks, if anyone has em, I could sure use em
Old 02-28-2011, 02:02 PM   #4
Well, I found the brackets off a 79 3/4 ton GMC truck but they are to deep/big. The mounting holes line up perfect but the grill sticks out way to far when I try and mount it My question is, are there shallower brackets for the 76? Thanks for any help!
Old 02-28-2011, 02:18 PM   #5
bigblock73
yeller
bigblock73's Avatar
Lets see the grill and core support...maybe you have some mismatched parts?
bigblock73 is offline   Reply With Quote
Old 02-28-2011, 05:25 PM   #6
They sure seem right, but they are too deep ???
Old 03-01-2011, 10:41 AM   #7
Chlsnk
Chlsnk's Avatar
Interesting i'm having the same problem.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 03-01-2011, 09:08 PM   #8
79gmcclassic
79gmcclassic's Avatar
is that grille NOS? cuz it looks nearly perfect!
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 03-01-2011, 11:20 PM   #9
bigblock73
yeller
bigblock73's Avatar
Are the brackets off the truck you are putting the grill in, or off another? They doo look awful deep, deeper than the ones I pulled off my 77 when I put in the 73/74 grill.
EDIT, saw your earlier post...duh. I think these are incorrect for the grill you have. I wish I kept the 77 brackets so I could compare, but I couldn't sell them so I pitched them.
Old 03-01-2011, 11:33 PM   #10
bigblock73
yeller
bigblock73's Avatar
There are some pics from a "76" core support in the following thread. The supports look similar, but I can't tell exactly. Also, who knows if it was really a 76 core support or not.
http://67-72chevytrucks.com/vboard/s...t=core+support
Old 03-01-2011, 11:47 PM   #11
texasfunk
texasfunk's Avatar
The grille looks to be a 73/74. They take a whole different set of brackets...
texasfunk is offline   Reply With Quote
Old 03-01-2011, 11:50 PM   #12
texasfunk
texasfunk's Avatar
Hmmmm..but comparing..I could be wrong...lol
Old 03-02-2011, 12:13 AM   #13
bigblock73
yeller
bigblock73's Avatar
That isn't a 73/74 grill
Old 03-02-2011, 02:16 AM   #14
bmchevy1979
bmchevy1979's Avatar
that is a 75/76 GMC grille I have one I would like to install on something but your brackets look a lot taller than mine. All of the pieces I have came off of the same truck pic is of left side bracket
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 03-08-2011, 06:50 PM   #15
Thanks for the input. I did the most bonehead move, I left the grill setting in the opening and forgot about it. A few days later I get in the truck and drive it around the corner.....the grill fell out and I ran over the corner of it!!!!!
