Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 02-05-2011, 03:31 PM   #1
michellenolimit
Junior Member
No Limit 63-72 Rear Shock Kit
NO LIMIT ENGINEERING
New Rear Shock Kit to fit 1963-72 Chevy Pickups!! "Quote per Rob" - I'm feelin pretty good about this. After dropping another 2" in back, we ran into the same trouble as everyone else. The shock issues. After researching the other kits, and solutions, and thinking about it, we came up with a plan. Here are some of the problems we noted. 1. No room for a longer shock, even with reworked or 'dropped' mounts. 2. shock angle gets worse, the lower you go. 3. If we go another 2" (8 total) we're screwed again. 4. the exhaust is a nightmare. 5. the inboard shock design doesn't handle that great. With this in mind, we set out for a fix. This is the whole idea behind the JT, to come up with tested components that WORK, and will HELP get more trucks on the road to be enjoyed.
Michelle
No Limit Engineering
Authorized Dealer for: Ridetech, Vintage Air, Painless, Ididit, Accuair, Flaming River, and many more
michellenolimit is offline
Old 02-05-2011, 03:32 PM   #2
michellenolimit
Junior Member
Re: No Limit 63-72 Rear Shock Kit
We are also using this forum, and site to set the record straight. I am sure we will be copied. Now there is lasting, dated proof, and those who 'knock-off' will be called out. This kit will come with 2 different length shocks. A 10" stroke shock for the stock to 4" drop guys, and a 8" stroke shock for the 6" to 10" drops. Once the stock shocks and mounts are gone, the new lower mounts are a direct replacement.
Michelle
Old 02-05-2011, 03:33 PM   #3
michellenolimit
Junior Member
The new upper mounts locate to the frame with a factory 5/8" hole. We provede a big bolt to hold and align the new mount. You have to drill the two 3/8" holes.
Michelle
Old 02-05-2011, 03:34 PM   #4
michellenolimit
Junior Member
Then your all but done. Just bolt on the shocks and mount studs, all included.
Michelle
Old 02-05-2011, 03:35 PM   #5
michellenolimit
Junior Member
Quote from Rob, "After some drive time, I am happy to report that the difference is clear. Body roll is reduced, and the ride is very smooth. The outboard location is a benefit in many ways. With a good quality monotube shock, these kits wil run about $185.00 I think thats a good deal for the gains. Just remember, You saw it here FIRST."
Michelle
Old 02-05-2011, 09:09 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Thanks for releasing your "New Products" here at 67-72ChevyTrucks.com.
We will be looking forward to future 67-72 suspension products from No Limit Engineering!
Keith
Convert to disc brakes.
lolife99 is offline
Old 02-05-2011, 09:28 PM   #7
m6z
m6z's Avatar
Looks good. Now I just need another truck.....
Doug
Looking for a 67-72 short bed driver.....
m6z is offline
Old 02-06-2011, 07:14 PM   #8
vincentgkirkland
vincentgkirkland's Avatar
will there be a coilover option
72 SUPER10
vincentgkirkland is offline
Old 02-22-2011, 02:03 PM   #9
65Gregg
65Gregg's Avatar
"This kit will come with 2 different length shocks. A 10" stroke shock for the stock to 4" drop guys, and a 8" stroke shock for the 6" to 10" drops. Once the stock shocks and mounts are gone, the new lower mounts are a direct replacement"
What about those of us that dropped 5"? Will you offer just the brackets/hardware?
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 02-22-2011, 11:14 PM   #10
Zoomin
Man of Mini-Talents
Zoomin's Avatar
I gather from the smoldering mount, this is not an unbolt the old and bolt on the new operation.
Is the price $185?
Combo price with the trac bar kit?
Zoomin is offline
Old 02-25-2011, 05:41 PM   #11
65Gregg
65Gregg's Avatar
I think Michelle at No limit posted and ran...
65Gregg
Blue long bed
White TBSS
61 Impala
65Gregg is offline
Old 03-03-2011, 09:05 AM   #12
lakeroadster
This is a duplicate post which violates Site Rule XIV:
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
A question about the strength of the lower mount for the No Lomit kit was previously posted and that post was transparently moved by an administrator to the "duplicate" post ???
Here is a link to the other post: http://67-72chevytrucks.com/vboard/s...Rear+Shock+Kit
lakeroadster is offline
Old 03-04-2011, 03:45 PM   #13
Custom 68
Custom 68's Avatar
pm sent but waiting for response.
Maybe I should call?
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is online now
Old 08-03-2011, 05:00 PM   #14
michellenolimit
Junior Member
Sorry guys, I have been out of the loop - for a LONG WHILE -
I'm back!!
These kits are all done, ready to go!!
A) 0-4" Drop Spring
(B) 5-7" Drop Spring
Part # 3GC-RR-100
Complete Mounting System----------$149.00
(without shocks)
Part # 3GC-RR-101 Specify A or B
So Cal Shocks-----------$73.00/pair
(soft and smooth)
Part # 3GC-RR-102 Specify A or B
Doetch Hydrolic-------------$119.00/pair
(mild/med, good with air bags)
Part # 3GC-RR-103 Specify A or B
Doetch Nitro--------$139.00/pair
(Med/Firm, canyon carver)
Part # 3GC-RR-104 Specify A or B
Bilstien Invertia Valve---------$258.00/Pair
Smooth, self adjusts to conditions)
Part # 3GC-RR-105 Specify A or B
Romic Billit with adjustable rebound-----$269.00/pair
Great for performance tunning
Please give us a call @ No Limit 909-386-7637 or pm me with a private message if you are interested.
Michelle
Old 10-05-2011, 11:59 AM   #15
volleyballer13
volleyballer13's Avatar
Michelle,
Just wondering if the rear shock kit will work on the 73-87 trucks that have been converted to trailing arm rear suspension? Love the kit and would like to use it on my truck. Thanks in advance.
Russell
volleyballer13 is offline
Old 12-08-2011, 09:58 PM   #16
master 1969 c10
Active Member
Hi Michelle
I have called u twice now and was told by a real nice lady who pick up the phone that u would call me back.I want to buy a set of the rear shock mounts but I want kyb gr2 shocks because I have a new set on the front can u give me a part # to one of the shocks so I can cross ref to the kyb I have a 1969 c10 s/b with a 4 inch drop coil
Thanks Doug
master 1969 c10 is offline
Old 12-09-2011, 12:39 PM   #17
robnolimit
robnolimit's Avatar
For that drop you would use an 'A' shoch length. 12" closed, 21" open, 17" RH. Both eyes are 5/8". Doetsch #3163 (hydrolic) #9163 (nitro), or Bilstien # 55-R042. Sorry for the delay, hope that helps.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline
Closed Thread
