Old 04-10-2002, 04:45 PM   #1
kman381
Post frame cut
DO you need to use a super "C" to knotch out the frame if you use a flip kit. I'm new to dropping trucks and want to find out as much info as possible so I do it right.
kman381 is offline   Reply With Quote
Old 04-10-2002, 04:54 PM   #2
78ondaflr
Post
No, super, or step notches are for extreme drops, 10" or more and you usually have to have an adjustable suspension of some sorts.
A bolt in notch plate should come with a flip kit, and that will allow plunty of clearence for the rear axle. I think you should pick up a copy of Truckin, or Streettrucks magazine.
78ondaflr is offline   Reply With Quote
Old 04-11-2002, 07:28 AM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Post
kman381,
A 5" drop does not require a "c" notch. The truck however will bottom out very quick. Anything over 5" should have a "C" notch.
You can use a shackel/hanger combo with some dropped leaf springs to get 5" very easily. There are several ways to drop your truck. All you need to do is decide which is easier for you and how much you want to spend.
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
[This message has been edited by gchemist (edited April 11, 2002).]
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-11-2002, 07:30 PM   #4
low 84
low 84's Avatar
Post
check out this post i made a while back about doing a c-notch, it should answer a few of your queations but feel free to ask more. you can also see the rear shackles that lowered it 2 inches in addition to the 5 inches from the flip kit. http://67-72chevytrucks.com/board/ub...ML/000177.html
Pot holes are my enemy
'84 1\2 ton swb, 350 5\7 drop
just sold '64 1\2 ton
4\4 drop with built 350 (my toy)
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
