02-09-2011, 04:03 PM | #1 |
rear bag bracket placement ?
Just wonderin how to determine where to put brackets on the rear so I have the proper air in the bags for ride height.It will be brackets welded on axle and a top crossmember setup.Is on a 78 blazer
02-09-2011, 06:58 PM | #2 | |
Re: rear bag bracket placement ?
Make a 'dummy' air bag to use as a set-up tool. A piece of pipe or block of wood the correct dimension for the bag @ manufacturers recommended specs (air psi & height) will work for this. One you have those two things done, you can get an idea of the placement required for the upper/lower brackets.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-09-2011 at 06:59 PM. |
02-09-2011, 07:13 PM | #3 |
thanks ,I didn,t know they gave you psi ,height etc with the bags.
02-09-2011, 08:06 PM | #4 |
While not an exact, their recommendations should get you started & in the ballpark.
