02-11-2011, 10:42 AM | #1 |
Window scrapers removed to r&r vent windows?
I want to put in new vent windows. I have never pulled them out so I want to know what to remove to make it easiest to r&r them.
I know how they are held in. Just curious about the surrounding stuff.
1970 Shortbed 2wd C-10 |
02-11-2011, 10:52 AM | #2 |
VA72C10
Re: Window scrapers removed to r&r vent windows?
I did mine before scrapers and I think you'd probably want them removed to make it easier to get it in/out. I followed the FAQ posted on this forum and it went super easy actually. Just put tape on your door inside and out to avoid scratches in the paint.
Looking for a 67-72 swb or blazer project in or around VA. |
02-11-2011, 11:07 AM | #3 |
Thanks. I searched and didnt see anything but I will go to the FAQ area specifically and look. I used the google search.Maybe the sites search will return it.
02-11-2011, 11:12 AM | #4 |
VA72C10
I know I saw another one as well....but this shows the technique I used to get them in/out w/ the least amount of hassle
http://67-72chevytrucks.com/vboard/s...d.php?t=178040
02-11-2011, 11:15 AM | #5 |
VA72C10
Here it is.....talks about all the screws you need to remove and also goes into the window regulator replacement. The biggest thing for me in getting it all in/out was leaving the guide/brace in the lower opposite corner loose until everything was in and loosening it/shifting it over to get everything out
http://67-72chevytrucks.com/vboard/s...ht=vent+window
02-11-2011, 11:18 AM | #6 |
Perfect. Thank you Sir. Search never found those threads.
02-11-2011, 11:23 AM | #7 |
VA72C10
You're welcome!
the site search tool is a tricky thing...took me a while to figure it out. I actually did use search to find them. Selected advanced search and typed in vent window. but then the trick was selecting only the FAQ forum and FAQ index tabs. I did that by selecting one then holding control to select the next one. If not you get way too many other bogus responses in the results... I also use this when looking for parts.....type what you're looking for then only select 67-72 classifieds....if too many results then change the search option to only search titles....
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 02-11-2011 at 11:24 AM. |
02-11-2011, 06:01 PM | #8 |
I did mine and most definantly had to remove scrapers. Tried to remove the first one with scrapers still in and it really bent them up. I was replacing them anyway so it did not matter, but it is easier to remove once scrapers are out. Good luck
