Old 02-12-2011, 08:52 PM   #1
juiceman650
juiceman650's Avatar
Heater hoses
I got a 1975 C10 and I'm gutting the a/c and heater. I was wondering how i could relocate my heater hoses (the ones running from my radiator and engine into the cab). Do i actually need them if Im gutting it?
juiceman650 is offline   Reply With Quote
Old 02-12-2011, 09:00 PM   #2
one low c10
Re: Heater hoses
not if you get rid of your heat.....just take out the nipple fittings and plug them with pipe plugs
one low c10 is offline   Reply With Quote
Old 02-12-2011, 09:06 PM   #3
juiceman650
Re: Heater hoses
you got any pictures?
Old 02-12-2011, 09:10 PM   #4
one low c10
Re: Heater hoses
no sorry
Old 02-12-2011, 09:13 PM   #5
juiceman650
Re: Heater hoses
well, what exaxctly do i do with the hoses?
Old 02-12-2011, 09:13 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Heater hoses
You'll just need a pair of 1/2 npt pipe plugs.
Old 02-12-2011, 09:15 PM   #7
juiceman650
Re: Heater hoses
to plug the actual hose? or can i plug the radiator where the hose connects and the same with the engine? I'll try to get some pictures in a bit.
Old 02-12-2011, 09:15 PM   #8
one low c10
Re: Heater hoses
cut them off if you want, they just go to the heater core which you will be removing anyway.
mine were 1/2 and 5/8 thread i believe
Old 02-12-2011, 09:25 PM   #9
TheApocalyptican
TheApocalyptican's Avatar
Re: Heater hoses
Unless I am missing something, you should be just completely removing one hose, and the other should route from the radiator to the engine.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 02-12-2011, 09:25 PM   #10
ont_guy_38
ont_guy_38's Avatar
Re: Heater hoses
You will have to plug the hose that comes off the rad or find a cap that fits and solder it on
ont_guy_38 is offline   Reply With Quote
Old 02-12-2011, 09:27 PM   #11
ont_guy_38
ont_guy_38's Avatar
Re: Heater hoses
Or do that if you want
Old 02-12-2011, 09:36 PM   #12
juiceman650
Re: Heater hoses
so i should take this hose and run it to the engine instead?
i meant the hose in the middle.
Old 02-12-2011, 09:46 PM   #13
TheApocalyptican
Re: Heater hoses
Yep, that's exactly what I was talking about. I do this every summer with my vehicles that don't have a heater control valve. Run that hose to the engine, and get rid of the other one along with all the other heat and a/c stuff.
Old 02-12-2011, 09:48 PM   #14
juiceman650
Re: Heater hoses
thanks a lot man.
Old 02-12-2011, 09:48 PM   #15
ont_guy_38
ont_guy_38's Avatar
Re: Heater hoses
Yes , looks like it might be a little swelled , maybe should be replaced
You guys are quicker then me
Old 02-12-2011, 10:03 PM   #16
one low c10
Unhappy Re: Heater hoses
mine must not be stock I have mine coming out of the water pump and intake, no outlet on my radiator.
Old 02-12-2011, 10:06 PM   #17
87 chevy silverado
Re: Heater hoses
its different from motor to motor
87 chevy silverado is offline   Reply With Quote
Old 02-13-2011, 05:31 AM   #18
juiceman650
Re: Heater hoses
yeah, Im planning on replacing all the hoses whenever i can. Im just working on pulling out all the a/c and heater stuff, and cleaning it up.
