Old 03-15-2003, 10:29 PM   #1
twistedmetal
Take it to the limit
twistedmetal's Avatar
Unhappy ***HELP***59 chev apache body transition to 4x4 what to use 4 donor???
wanting to do a 4x4 conversion to a 59 apache..was told the frame from a full size 73-87 blazer will work,What is the easiest way to change this truck over so i can have some fun with it.any articles,pix or whatever will help thanks all.
"If Fall Guy only knew how many trucks i've wrecked,He'd be proud"
1995 GMC SLE Ext cab 4X4 Z-71 loaded daily driver 87 k25 Fully Loaded inc captain buckets and console,12" susp lift,3" body lift 42"swampers
66 Cutlass 2dr hardtop currently undergoing frame off
55 chev 2dr hardtop awaiting attention
85 Chev silverado 1/2 ton loaded,daily driver(stolen)
80 chev silverado 1/2 ton farm truck
87 S-jimmy V-8,lowered ,Parting out
49 Chev 1/2 parting out
parting numerous 73-80 chev trucks
01 Polaris edge X (highly modified)
58 NSU Prima scooter awaiting total restoration
twistedmetal is offline   Reply With Quote
Old 03-15-2003, 11:08 PM   #2
pugs
pugs's Avatar
re
i would just put reaes and spring from a 4x on your original chassis
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 03-17-2003, 09:26 AM   #3
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
I just looked at an 84 blazer for the same purpose this weekend.
The springs would have to be moved back about 10". This would put the rear spring perch right on the rear of the frame. The bolts would be within an inch or less from the rear of the frame so something would have to be done there to reinforce the mounting.
When moving the purches back the angle/contour of the frame changes so additional fabrication would be needed to keep the springs square with the axle.
This also moves the axel back from the frame hump although if it is kept high enough this looked like it would clear.
When the front perch is moved back it would mate the frame in a higher position and this would lower the rear also.
I will be looking for a truck 4x4 chassis
If I find out any more info I will post and if you hear of any more options please post.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 03-17-2003, 06:48 PM   #4
twistedmetal
what about an extended cab shortbox 4x4 s 10 hav you checked one of them out or a longbox reg cab.this may put everything closer with just having to trim the rear frame rails a bit.
Old 03-17-2003, 09:13 PM   #5
DennyB
DennyB's Avatar
The s10 long bed is close. (117.9")
A '99 Silverado wheelbase is 119"
I have owned a few s10s and there front suspension wears out easy and Im looking for something a bit more sturdy.
I have not owned a s10 4wd though so...
I am also concerned with the s10 rear wheel base clearing the 4 foot wide bed of my 56. s10's are skinny, there length between wheel housings of the stock bed is 40.4". Perhaps a wider axel would solve that for you, but then the wheels wouldn't "track"
Do you have the exact wheelbase required to center the wheels in the openings of a 55-59 SWB stepside?
I was thinking in the area of 115"????
I.M.O.M,W,J&C
Patriot Guard Rider
Old 03-18-2003, 08:45 AM   #6
DennyB
DennyB's Avatar
I checked the factory assembly manual and it list the wheelbase for the 3100 as 114"
I.M.O.M,W,J&C
Patriot Guard Rider
Old 04-11-2003, 06:44 PM   #7
Bluegoose972
Try looking at the frame assembly of the 73-87 SWB 4x4 pickups. I've been doing a little research into this lately. These years of trucks match up very closely to the wheelbase for the 55-59 Short wheelbase trucks. The 69-72 models measure at 115" (vs 114" for the 55-59 models) and the 73-87 models measure 117". I believe it is a fairly simple process to remove a 3" section from the mid frame area on these trucks. The 73-87 models should be fairly easy to locate at a good price.
Bluegoose972 is offline   Reply With Quote
Old 04-12-2003, 09:33 PM   #8
twistedmetal
Cool ,thanks Blue
Old 04-13-2003, 05:42 PM   #9
Lucky59
Do you feel Lucky...?
Lucky59's Avatar
My 59 is on a 76 Blazer frame, not a 4x4 but still. Yes it has to be cut a few inches. I dont know the exact specs of the chop, seing as how I didnt do mine. I will have some pics on here in a few weeks so i guess i can take a few of the frame if it will help out any.
Lucky
1959 Chevy Shortbox Stepside
1969 Chevy Custom C/10
1991 S-10 Blazer Sport
2003 Dodge SX2.0 R/T
2001 Mountain Cat 800 LE
Lucky59 is offline   Reply With Quote
Old 04-13-2003, 08:21 PM   #10
twistedmetal
any pics of the body mounts and the frame would be greatly appreciated,thanks
Old 04-14-2003, 12:46 PM   #11
DennyB
DennyB's Avatar
Lucky
Lucky,
The blazer w/b is about 9" to short. Did they relocate the rear springs?
Got pics?
I.M.O.M,W,J&C
Patriot Guard Rider
Old 04-14-2003, 06:57 PM   #12
Lucky59
Lucky59's Avatar
Yeah I will get some pics pretty soon. Probably later on tonight, any other parts u want specific pictures of, besides the rear springs...?
Lucky
Old 04-14-2003, 07:43 PM   #13
Lucky59
Lucky59's Avatar
Here are some pics... alot of pics rather...
hope some of these help
Lucky
Old 04-14-2003, 07:45 PM   #14
Lucky59
Lucky59's Avatar
another mount pic...
Old 04-14-2003, 07:52 PM   #15
Lucky59
Lucky59's Avatar
Back end
Old 04-14-2003, 07:54 PM   #16
Lucky59
Lucky59's Avatar
sorry for small back end pic... engine pic now
Old 04-14-2003, 07:56 PM   #17
Lucky59
Lucky59's Avatar
inner fender..
Old 04-14-2003, 07:59 PM   #18
Lucky59
Lucky59's Avatar
where it is shortened...
Old 04-14-2003, 08:02 PM   #19
Lucky59
Lucky59's Avatar
i doubt this makes a difference, but here are a few additional pics, the box...
Old 04-14-2003, 08:04 PM   #20
Lucky59
Lucky59's Avatar
front end of truck
Old 04-14-2003, 08:05 PM   #21
Lucky59
Lucky59's Avatar
cheap seats... got these babies for 15 bucks, plus seatbelts...
Old 04-14-2003, 08:06 PM   #22
Lucky59
Lucky59's Avatar
Papa Larry's Chevelle...
Old 04-14-2003, 08:08 PM   #23
Lucky59
Lucky59's Avatar
and the final picture, a pic of the rims on my truck, does anyone know the make, they say Progressive on the center cap but I cannot find another set of caps for them as the front caps are Cragar, and I doubt these are Cragars
Old 04-14-2003, 10:45 PM   #24
twistedmetal
hey bud,as for the center caps i have 1,maybe 2 if i dig.we need more people like you on this site,those pix are great and will help me lots,thanks.as for the caps they are yours just pay me the shipping.if they are wrong though,i thing they can be bought at softy's speed shop in winnipeg mb.keep in touch,and thanks again for the pix.
Old 04-14-2003, 11:18 PM   #25
Nova_Cobra64
Nova_Cobra64's Avatar
Sure man, just post your truck and the chevelle.......don't want to look like a car hoarder now do you?
Why don't you get some pics of the firebird, impala, or belair? I haven't really seen any of them.......
2004 Silverado - Beater
1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683
2011 Aveo - Work commuter
2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck.
Nova_Cobra64 is offline   Reply With Quote
