Old 02-17-2011, 12:00 AM   #1
Hart_Rod
Hart_Rod's Avatar
Gears for a T56?
What would be a good gear to run with an LS1/T56 with 30" tires?
Hart_Rod is offline   Reply With Quote
Old 02-17-2011, 09:40 AM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Gears for a T56?
4.10 Luckily with the 6 speed that gear works great. A buddy of mine ran that in a Camaro with no issues and a 28 inch tire.
--Josh
Old 02-17-2011, 09:49 AM   #3
swb85
On a budget like Fred Sanford
swb85's Avatar
Stock or modded? If it's a 1/4 mile app, need to know about what mph you're going to be at through the traps.
Otherwise, you can run a TON of gear with 30" tires and a t56. The .5:1 sixth gear makes for crazy low rpm cruising. If it were me, I'd go 4.56 at a MINIMUM. Check out how low your 70mph cruising rpm would be with:
4.56 = 1800rpm
4.88 = 1900rpm
5.13 = 2000rpm
I run 4.30's with a 28" tire in my camaro only because of the nitrous. If she wasn't bottle fed I'd have 4.88's!
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 02-17-2011, 09:55 AM   #4
no moa
no moa's Avatar
My impala ss will use an m29 t56 with 373 rear gears running the stock 255/50/17 tires. But that is a car not a truck.
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 02-17-2011, 10:05 AM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks for the info guys. This is in a 68 SWB that I'm going to build for my son's first truck. I've read somewhere that if you go to low (numerically high) with the gears that it makes first gear useless, but if you get to high (low numerically) that the overdrive will be useless. The motor and tranny are out of a 02 WS6. I checked the specs on it and it had a 3.23 gear with a 25.6" tall tire. I think a 3.73 with a 30" tall tire is about equivalent. Thoughts?
Old 02-17-2011, 10:10 AM   #6
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
I would go 4.88 or even 5.13 with a 30" tire. That t56 could use all the help it can get under a heavy truck. They have an insanely high ratio overdrive, so you will have plenty of road gear.
A friend of mine in highschool had a H/C + Nitrous 98 Camaro with the t-56 and 27" tires. He swapped in 4.10s and it still cruised at less than 1500 rpm at 60, and would go faster than you would ever need to on the top end.
On a heavier truck you are going to want to be cruising around 2000 on the highway to be in a decent torque range to pull it along, otherwise you will NEVER even use 6th gear.
Edit: Love the look of that truck, should be fun, and yes 1st gear may become useless in most driving, but is still nice for starting up hills.
Yea, 3.73 is close to equivalent with the car it came out of with 3.23, but again you are going to want more mechanical advantage, because not only are those wheels and tires larger diameter, they are also heavier, and the truck is much heavier.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 02-17-2011, 10:23 AM   #7
Hart_Rod
Hart_Rod's Avatar
This site is calling the curb weight of the WS6 around 3500 lbs. Isn't that about what most SWB trucks weigh?
Old 02-17-2011, 11:01 AM   #8
GCncsuHD
GCncsuHD's Avatar
Curb weight of a SWB is right around 4,000 lbs, that stepside with a wood bed may be a little lower.
Stil would go with atleast 4.88s with those 30" tires in a truck.
ΜΟΛΩΝ ΛΑΒΕ
Old 02-17-2011, 12:22 PM   #9
Shon
If it were mine to just DRIVE, I would get a 4.10 or 4.33s with a 30" tire.
if it were to get every tenth out of it on the track will take a little more thought.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 02-17-2011, 12:36 PM   #10
GCncsuHD
GCncsuHD's Avatar
I'm still going with 4.88 or better.
That setup with 5.13s and 30" tires you will be shifting out of first gear at 20mph at 3000rpm for example, that is more road speed than 2nd gear in my sm465 and 4.10s, so 1st gear would not be useless IMO. Then at 70mph you are looking at 2011 rpm, a good cruising speed in my opinion, and much lower than the stock setup with no OD.
And assuming a 6000rpm redline, you still have a top speed in 6th gear of 209mph with 30" tires and 5.13s
ΜΟΛΩΝ ΛΑΒΕ
Old 02-17-2011, 02:31 PM   #11
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
going to be a tire burner for sure.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 02-17-2011, 04:33 PM   #12
kSStamp0182
LSX addict
kSStamp0182's Avatar
i had a 2001 SS T56 and even with 4.10s 6th was almost useless unless your doing 80. id agree with 4.88s minimum.
-1982 C10 SWB GMC Sierra [undergoing 6.0/4L80E swap with mild restoration]
kSStamp0182 is offline   Reply With Quote
Old 02-17-2011, 04:35 PM   #13
swb85
swb85's Avatar
The t56 first gear is only 2.66:1. With 4.56's, you'd redline in first gear at 45mph....4.88's and it's 42mph. You gear it much higher than that with such a tall tire and you're going to have to slip the clutch excessively to get moving and you won't be able to use 6th gear until 70+mph.
Old 02-17-2011, 10:34 PM   #14
TR65
TR65's Avatar
Rob,
I run 3.73 gears with 29" tires, T56, LS2, 390 hp out of an SSR.
I think it is a perfect gear for a daily driver. Plenty of low end, first gear very usable. I use 6th gear all the time even at lower speeds. Cruise at 70 mph is 1800 rpm. Good mileage, good accel.
By the way, the SSR weighed 4750 lbs. The C10 weighs less than 4000.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 02-17-2011, 10:54 PM   #15
GCncsuHD
GCncsuHD's Avatar
Originally Posted by TR65 View Post
Rob,
TR
The SSR T56 is different than the car t56. It's 1st gear is much lower than the car ratio, it would become useless faster than the car 1st gear, and it's 6th gear is also a lower ratio as well, it is better suited to a higher gear ratio than the car transmission.
Vette/Camaro ratios
1st 2.66
2nd 1.78
3rd 1.30
4th 1.0
5th .74
6th .50
SSR ratios
3.01
2.07
1.43
1.0
.84
.57
GTO/CTS-V
2.97
2.07
1.43
1.0
.84
.57
ΜΟΛΩΝ ΛΑΒΕ
Old 02-18-2011, 06:23 PM   #16
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'd want 4.10s unless the truck already has 3.73, then I would wait to see how it drives.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-18-2011, 10:22 PM   #17
TR65
TR65's Avatar
So, it looks like the GTO/CTS-V and the SSR are equivalent, except a very small difference in first gear. So the question is, what did Rob's T56 come out of?
The SSR T56 is also the M12 version that has a single piece tail shaft, steel shifter forks, stronger gears and some other mods for reliability in a heavy truck like the SSR.
TR
1965 C10 SWB Fleet
Two owner
Old 02-19-2011, 12:06 AM   #18
Hart_Rod
Hart_Rod's Avatar
The SSR T56 is also the M10 version that has a single piece tail shaft, steel shifter forks, stronger gears and some other mods for reliability in a heavy truck like the SSR.
TR
Pontiac Trans Am WS6
Old 02-21-2011, 11:21 PM   #19
Custom 68
Custom 68's Avatar
he neat thing about it is that 5th is teh same as overdrive in a 4l60 so u can use it alot. I have a t56 i am gonna swap and have 3.73 again with 5th being what it is I think it will be very usable then the highway u can use the 6th.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 02-22-2011, 02:11 AM   #20
skoffice
skoffice's Avatar
Check this thingy out:
http://www.grimmjeeper.com/gears.html
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 02-22-2011, 09:01 AM   #21
GCncsuHD
GCncsuHD's Avatar
Unless you are using really tiny tires, you won't be using 6th much at all on the highway unless you move to Germany and run the Autobahn. 70mph would only be 1450 rpm with 30" tires and 3.73. That is barely chugging along, and I doubt you will overcome the force of the wind and the weight of the truck much at those rpms, especially when you climb any bit of a hill.
Originally Posted by skoffice View Post
What I use for all my calculations
ΜΟΛΩΝ ΛΑΒΕ
Old 02-22-2011, 10:46 PM   #22
TR65
TR65's Avatar
Man, I use 6th gear all the time at 45-50 mph (1100-1300 RPM). (235/75-15tires and the 0.57 ratio 6th, 3.73 rear). I guess the engine has a lot of torque.
TR
1965 C10 SWB Fleet
Two owner
Old 02-23-2011, 10:15 AM   #23
GCncsuHD
GCncsuHD's Avatar
TR
Your 6.0 has considerably more low down torque than the ls1 and you have the benefit of the lower 6th and 28.5" tires.
ΜΟΛΩΝ ΛΑΒΕ
Old 02-23-2011, 11:14 AM   #24
Jonboy
Slots go on anything!
I don't know what the height of the tires was on my CTS-V (245/45ZR18), But it was about 4200 lbs and had 3.73's in it. 6th gear at highway speeds was around 1800 (80 MPH). I don't think you would want to gear it too low so he might be able to get a little mileage out of it.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-23-2011, 11:37 AM   #25
GCncsuHD
GCncsuHD's Avatar
26.7 tires and the lower .57 6th gear....
Even with 5.13s and that 30" tire he will be looking at only 2000 rpm at 70 in 6th gear, that is pretty ideal for fuel mileage, also consider that your V was not a flying brick, and did not need to overcome the drag nearly as much as one of these trucks would.
Considering a stock 3speed would be looking at 3100rpm at 70mph with the stock 3.73s and a 30" tire, I think the 5.13s with the t56 would be great at 2000rpm at 70.
ΜΟΛΩΝ ΛΑΒΕ
