02-24-2011, 12:05 PM | #1 |
Aftermarket door quality?
What is you opinion on aftermarket doors? Do they fit well?
Should I just reskin and repair what I have?
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
02-24-2011, 12:09 PM | #2 |
Re: Aftermarket door quality?
My truck has AM doors on it and I'm pretty impressed with them. The fit is actually pretty good. I have no complaints. I believe they came from LMC but I'm not sure. They were on it when I bought it. They're just in primer now. I can post pictures if needed.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
02-24-2011, 12:49 PM | #3 |
the common opinion around here is they suck ...
02-24-2011, 12:58 PM | #4 |
I would agree. For the most part original metal is better than aftermarket as far as fit and quality. If I needed doors I would try and locate a good used set of doors. JMHO
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-24-2011, 01:10 PM | #5 |
Junior Member
Use original doors if at all possible, its better to reskin one the mess with aftermarket... But as far as aftermarket goes I have had pretty good luck with the Goodmark stuff...
02-24-2011, 07:33 PM | #6 |
The PO installed the ones I have now, and I'm not about to take them off to put decent / marginal / re-skinned originals on. I have searched the world over for good GM metal for my truck where it was needed and paid top dollar for it but these are good enough IMO. I don't have a welder or the skill really to cut and re-skin original metal. So before I say 'They suck' .. I'm just saying I'm using AM because they're already on the truck. I have a decent set of originals I will sell if someone wants them.
Nothing about a 67-72 truck sucks in my opinion. I see tons of guys using aftermarket metal on their projects.. some good, some bad. LMC couldn't sell aftermarket metal, Year One, or anyone else for that matter if it sucked. They're making entire shells now. For what it's worth, my aftermarket doors leave nothing to be desired. The fit and alignment is really good. I will use them and be proud to drive my truck. I'm sorry you guys haven't had better luck with them.
02-24-2011, 09:09 PM | #7 |
The NEW Key Part 67-71 Doors fit better than anyother door on the market and are even seven pounds heavier than Tri-Plus, LMC, Goodmark, and Counterparts doors.
02-24-2011, 09:17 PM | #8 |
I swear...if you found a nos door or fender, gave it to someone to install and told them it was aftermarket, they would spend days trying to install it so it fit perfectly. It would all in end in tears and racist comments.
It's bloody hard to install properly.
71 GMC 1500 LWB |
02-24-2011, 09:59 PM | #9 |
02-24-2011, 10:34 PM | #10 |
02-24-2011, 11:04 PM | #11 |
trucks72
It is a roll of the dice on all of them. No matter who makes them. I have installed a lot of them. Some of the skins are on wrong, some are to thick, but most had the post to high and had to be lowered. After you fit them and work on them awhile they work great.
02-24-2011, 11:42 PM | #12 |
As trucks72 said, it's a roll of the dice. If you are cool with possibly losing $700+ or don't mind bad door gaps then go for it. I gambled and lost out. I ended up with garbage. After many hours of work they had to go. I later found a set of original doors and they fit like a glove.
Functionally, aftermarket doors will work but if fit and finish are high on your list, don't even waste your time.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
02-24-2011, 11:56 PM | #13 |
Has anyone done door skins? If anyone has what are the best skins to use and are they difficult to put on?
Posted via Mobile Device |
02-25-2011, 12:02 AM | #14 |
I hate the ones on my truck (tri plus) bought around 2005.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-25-2011, 12:36 AM | #15 | |
Member #1049
So fall all the repoductions I've installed have needed the drivers side window frame lowered at the rear. The passenger sides all fitted good, all the skins have been thinner than OEM.. but they are new, straight, not rusty and fit fairly well. On a funny note I have a 72 Cheyenne Super in the shop that needed a drivers door, and the customer insisted on NOS.. so I found him one to the tune of $900, and it fits horrible.. the window frame was way out of whack, I could litterally put my fingers between the top of the frame and cab.. I couldn't drill out the welds and reposition by lifting it up, the curve was way off, Still had to cut it apart and take a window frame off of another door and fit to the NOS one!! So much for the "NOS is better" theory!! Its still a roll of the dice. I could of bought 3 reproductions for the price of one NOS door.. Oh well "the customer is alway right" |
