Old 02-25-2011, 11:16 AM   #1
youngrodder
youngrodder's Avatar
Rear fender bolt size? 47-53
What is the size of the bolts that hold the rear fenders to the bedsides?
Thank you for your help.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-25-2011, 01:09 PM   #2
mr48chev
mr48chev's Avatar
Re: Rear fender bolt size? 47-53
5/16 x 3/4 if you use bolts or machine screws with a screw head from the hardware store.
I'd suggest buying a set of the right bolts from one of the truck parts suppliers though as the others never look quite right to me and I have run the wrong ones with slotted screw heads for close to 30 years.
Old 02-25-2011, 02:03 PM   #3
youngrodder
mr48chevy-
Thanks, I have something in mind with some specilty washers and I wanted to make sure I have the correct size prior to ordering them.
I apprecaite the reply...
Marc
Old 02-25-2011, 06:06 PM   #4
BigJock
youngrodder, sorry to get all European and metric,but I drilled out my fender holes to 10mm and used 10x25mm Button head stainless bolts with stainless nyloc nuts and washers.
I've polished them up(real easy with a sisal buff and white rouge)
Seeing as you're obviously going down the custom route,you should be able to get something similar in the U.S.A. but in more familiar UNF sizes.
BigJock is offline   Reply With Quote
Old 02-25-2011, 06:21 PM   #5
bretcopsey
I have been able to find stainless button head bolts in the local hardware stores "Hillman" selection that might look good polished up...
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 02-25-2011, 11:44 PM   #6
youngrodder
Thanks for all of the suggestions. I will post some pics of my idea once my specialty washers come in.
Marc
Old 02-26-2011, 03:55 PM   #7
mr48chev
mr48chev's Avatar
Those Stainless Buttonhead screws do look good when you put them in places where they show.
Old 12-05-2014, 07:00 AM   #8
fisherman420
Marc
what hardware did you end up using on your rear fenders? As mine sits in mock-up I'm just using a few standard 5/16" bolts and fender washers
fisherman420 is offline   Reply With Quote
