Old 02-28-2011, 10:56 PM   #1
Tmwoodall
67 SWB roller, 20" wheels, Roll Pan, and more
I have a smattering of parts laying around from when I started my build years ago that I no longer plan to use. Starting at the bottom:
1 Steel bed floor repair panel paid $22 + oversized shipping charges + taxes looking for $20.
Steel Roll pan from LMC with license plate recession. Never mounted, painted or hardly touched. It looks as if I just took it out of the box. Paid $120 + oversized shipping charges, + taxes. Looking to get $110
Epic Blix 20" wheels + Eagle GT II 8.5" wide 45 profile. They have never seen a mile of pavement. I have noticed that one of them has a small bit of flaking on the inside dishing of a wheel. Paid ~$1,500, looking for $900 or trade for Coy, 338, or other "modern" 5 spoke wheel.
Lastly I have the truck that was up for sale here for several months by another member. I have pulled the bed, grill, and fender. I replaced the hood with one I had, because I am more comfortable dealing with a bit of rust than I am the dents on the current hood. Looking for $400 OBO on the truck.
V8 3 Speed, in the floor, 6 lug, all basic. Lots of pictures here:http://gallery.me.com/tmwoodall/100081
Let me know if you want any details I am happy to provide any and all. The parts are all located in Austin Texas, but could make a trip with me to the Dallas area mid March.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
Old 03-01-2011, 08:47 AM   #2
rich67
rich67's Avatar
Re: 67 SWB roller, 20" wheels, Roll Pan, and more
what about driver side fender? have it or no? rich
rich67 is offline   Reply With Quote
Old 03-01-2011, 09:35 AM   #3
Tmwoodall
I do, I was planning on keeping it because the one I had for my truck and it, are in very close to the same shape. I am not sure which I will end up using when it comes time for bodywork. If it became a dealbreaker I am sure I could part with one, though it will be the lesser of the two.
Old 03-01-2011, 09:37 AM   #4
Tmwoodall
A few more details on the truck:
The frame appears to be totally straight and in good shape. It is a good candidate for a restore. The cab is not in as good of shape. It has rust in the kick panels on the passenger side, rockers, and a few small spots in the floor. I have taken pictures of every problem area that I know of in the album below. The cab could be brought back to life without that much work if one was so inclined. If you want to see a different shot, just let me know.
The hood has a dent in the crest of the nose that had some body work started on it, the same for the drivers corner it had a small dent. The underside is coated in semi-gloss frame epoxy and is actually in pretty good shape. There is NO rust on the hood at all. The fender has some issues that are shown in detail in the album below. Both problem areas are repairable with patch panels from any number of vendors. The cowl panel someone decided to shave the antenna hole with a panel from a blazer and it is sloppily welded on. It could be cleaned up and easily used for a shaved cowl.
What is good: Doors, back glass, frame, transmission?, drive shaft, rear end?, axles, steering, gas tank, hood, and I am sure more that I overlooked...
The seat pictures is not original, but seems to be a good fit. It has a fold down arm rest next to the driver. It is not bolted, but just in the cab loose. It is not in pristine shape but could be used.
I DO NOT have a title, or even a vin plate for the truck.
Old 03-01-2011, 01:53 PM   #5
tampz67@yahoo.com
Interested in the fender
tampz67@yahoo.com is offline   Reply With Quote
Old 03-01-2011, 03:53 PM   #6
Tmwoodall
I'll get some more pictures of the fenders up tonight. I'll also pull out my third I was planning on hanging onto and throw it into the mix so that there is a set if someone is interested in the set.
Old 03-01-2011, 04:20 PM   #7
trapperjack
trapperjack's Avatar
If you are going to cut up the cab, I'd be interested in the d side door pillar from fllor to roof, to patch this one...basically a piece like I outlined . I'm near Liberty Hill, so you're probably not far away.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 03-01-2011, 04:25 PM   #8
Tmwoodall
IIRC that part is actually in fairly good shape, save for a speaker hole cut below the glass on the interior. If I start cutting, we can work that out I am sure. I am right in Central Austin, so probably 30 minutes from you.
Old 03-01-2011, 04:44 PM   #9
trapperjack
I hope you sell it, but if it comes to cutting, let me know. I'll pm you my info. I've got a sawzall and an air chisel, i could help you cut.
Thanks.
Old 03-02-2011, 04:58 PM   #10
AusTruck
I'm interested in the steering column, clutch pedal, and z-bar stuff.
Located in beautiful south Austin too,,,for the right price, I'll pull the stuff.
AusTruck is offline   Reply With Quote
Old 03-02-2011, 05:33 PM   #11
Tmwoodall
PM or post up a price. I am open to parting/offers right now.
Old 03-02-2011, 11:35 PM   #12
Tmwoodall
Photo of the second fender. It is in considerably better shape than the other that I have for sale (which can be seen in the album link listed above).
The biggest issue with it is the inside cup is bent on the inner fender, as shown. It has a slight bit of bondo on it, you can see where I started and never finished a few small dents on the front near the headlight housing.
Those interested in fenders, PM or post up if you are still interested.
Old 03-04-2011, 03:36 PM   #13
Tmwoodall
Ttt
