Old 03-02-2011, 12:50 AM   #1
59weasel
would like to see some non-notched trucks.
i love the look of the truck layin frame. but on my 59 SWB i don't want to mess up the bed. call me old school, but i would like to see some that are layed down an out with out notching the frame and redoing the bed floor. i guess i'd just like to get a visual on what mine might look like. as i have no desire to cut up my floor. thanks!
59weasel is offline   Reply With Quote
Old 03-02-2011, 11:17 AM   #2
GhostTown
GhostTown's Avatar
Re: would like to see some non-notched trucks.
I don't have a wild notch, so I'm simply raising my entire bed floor 3 inches.
GhostTown is offline   Reply With Quote
Old 03-02-2011, 11:55 AM   #3
MrDude_1
The only way i know of that you can lay frame without notching the frame would be to have an independent rear suspension.
then again, on these trucks, you can lay running boards, without laying frame...
so if you do a mini-notch, a slight body drop, and raise the bed floor, it may look like almost nothings changed, but you can lay running boards...
MrDude_1 is offline   Reply With Quote
Old 03-02-2011, 04:18 PM   #4
59weasel
yeah, ive done a bunch of measuring on the truck and frame in the driveway. and transfered those numbers to the virgin 59 frame in the garage that will be the one that is going in. (REALLY, REALLY bad camaro clip done from P.O. so i got a fresh frame to start with.) and the truck outside is just a little tall for my taste. would like to see what it might look like with it down an inch or so. thanks guys.
Old 03-02-2011, 10:28 PM   #5
JMR5
JMR5's Avatar
My 59 isn't very low, but you can see what it looks like riding on a stock straight axle with 3 leafs pulled from the front, 3 leafs pulled from the rear and extended rear shackles.
JMR5 is offline   Reply With Quote
Old 03-02-2011, 10:42 PM   #6
fiddy9apache
fiddy9apache's Avatar
no rear notch, rear tire is a 295/50-15... but it will be notched just so i can haul heavy stuff like engines, trans, and cases of beer.
fiddy9apache is offline   Reply With Quote
Old 03-03-2011, 12:28 AM   #7
59weasel
thanks guys. nice rides!
JMR5 thats a nice lookin truck got a nice stance.
fiddy9apache also a sweet ride. and looks about like the stance i hope to pull off. is it subframed? how much rear travel do you think you have? a couple guys from work say i need at least 5" from axle to bottom of frame. i dont plan on haulin much, but a little butt! and i'm baggin all 4 corners.
thanks again.
Old 03-03-2011, 10:42 AM   #8
entourageguy
Yellow truck club
entourageguy's Avatar
mine has a c notch with out any bed mods.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-03-2011, 05:38 PM   #9
59weasel
your truck looks so koooool!! i love the old school white walls and all! but i'm a nebie and just dont see how i can get it that low without a notch. it just seems like your pumpkin would hit the bed floor, or the axle tubes would hit the frame rails. is there any way i could get a pic or two of the rears on these trucks?
