Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-03-2011, 09:57 PM   #1
TexasJimmy
TexasJimmy's Avatar
71' Blazer Initial Start Up Advise
I will bring my new 71' Blazer home on Saturday. It has set up in a garage for 3 years. This is how I plan to start it for the first time. Any advise is welcome.
1. Drain fuel tank, and add fresh gas.
2. replace all fluids.
3. Pull plugs and add ATF to cylinders.
4. Disconnect fuel line at carb.
5. Crank until fresh fuel is seen without spark plugs installed.
6. Replace plugs and crank it up.
7. If float is stuck, tap on carb to release.
Am I miising anything?
Thanks Tim
Here are some pics.........
http://www.kodakgallery.com/gallery/...14%3A594592991
TexasJimmy is offline   Reply With Quote
Old 03-03-2011, 11:06 PM   #2
AJs72K5
AJs72K5's Avatar
Re: 71' Blazer Initial Start Up Advise
Link doesn't work Tim.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 03-04-2011, 12:03 AM   #3
my90k5
72 K/5 Junkie
my90k5's Avatar
No pic's on the link....
I used marvels mystery oil in each of the cylinders when I started mine up after 1 year (prob same as trans fluid). Would like to see some pic's tho.
72 k/5 CST 350 SM465 NP205
My Build Progress
my90k5 is offline   Reply With Quote
Old 03-05-2011, 12:19 AM   #4
TexasJimmy
TexasJimmy's Avatar
Lets try these....I just got it home tonight. I will keep you posted. The rig was purchased about 40 miles from my house in 71'. One family owner. All records, manuals, and even the protecto plate.
http://www.kodakgallery.com/gallery/...hotos-_-Sharee
