03-05-2011, 03:36 PM | #1 |
:confused: Brakes Locked Up!
I was on the way back from the dump with my son and I noticed the brake pedal was hard all of a sudden. The brakes seemed to be on with no help from me! About a block later I had to stop when I saw smoke coming from the rear brakes. So now my 1969 C/20 is a few blocks away stuck and I had to walk home. Any ideas? Thanks in advance!
03-05-2011, 03:42 PM | #2 |
Re: :confused: Brakes Locked Up!
emergency brake is on
03-05-2011, 03:51 PM | #3 |
It's all in the timing
x2,did you set the e-brake at the dump,released them and they stuck.Tends to happen with old cables.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
03-05-2011, 04:01 PM | #4 |
Active Member
Happened to me many years ago. Probably a collapsed rubber brake hose on the rear passenger side of the axle. Allows the fluid to be forced to the brakes but not enough spring tension to return it to the master cylinder. Common problem on these old trucks.
I'd replace all three of them. The two in the front and the rear one. |
03-05-2011, 04:27 PM | #5 |
The e-brake pedal isn't on and it barely worked anyway; could that still be it or is it more likely brake lines? I had to replace the left rear line when I got it as it was rusted through. Maybe I should do them all? Ive got to figure out a way to get it home first though! Thanks for the help so far!
03-05-2011, 04:35 PM | #6 |
Active Member
It's the rubber hoses that go bad. You can't see it from the outside but the inside swells up to the point where fluid is restricted and not able to return.
Best way to check is to loosen the brake bleed valve on the side that's stuck and see if it unsticks it. If it does then you have a restriction and more than likely it's those rubber hoses. |
03-05-2011, 05:29 PM | #7 | |
03-05-2011, 05:34 PM | #8 |
Do not try to drive it with the bleeders open,you will loose all the fluid and suck air into the system= no brakes.
03-05-2011, 05:38 PM | #9 |
Hmm, wouldn't I still have front brakes? When I got it I limped it home with a hole in the rear line (14 miles). I would have to go about half a mile to get it home now.
03-05-2011, 05:46 PM | #10 |
Well you did not say how far you had to go.I would do it,just be carefull.Follow someone you know,if the brakes fail at least you hit someone you know.
03-05-2011, 05:52 PM | #11 |
03-05-2011, 06:06 PM | #12 |
If you release the pressure and that works go light on the brakes until you get it home and get it fixed.
Just drive it like you don't have any brakes at all and give your self enough room to slow way down at lights and make gentle stops when you need to. But keep the bleeders closed after you release the pressure even if you have to do it again a couple of times. Last edited by mr48chev; 03-05-2011 at 06:08 PM. |
03-05-2011, 07:16 PM | #13 |
if you drive it with the bleeder open you will not have any petal loose all your fluid and stroke the master and fill the system with air
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
03-05-2011, 11:23 PM | #14 |
I got it home in one piece- the brakes weren't locked up anymore. I will replace all of the rubber lines and go from there. Thanks again for the help. This forum is awesome!
Paul Posted via Mobile Device Posted via Mobile Device |
03-06-2011, 07:48 AM | #15 |
you should change those rear shoes,pay special attention to the drums as overheated they tend to get warped and also with the heat treatment they glaze over and the result is poorer brake performance
