Old 03-05-2011, 05:53 PM   #1
kikkegek
kikkegek's Avatar
Rattling sound driver side of the engine, please help!
hi guys,
I need some help.
I had a small allmost not audible rattle on the driver side of the engine. Went to a shop and it is so hard to hear, that they didnt make a point of it..."it's nothing, dont worry!"
It even went away and then came back and went away...
then when I flushed the cooling system recently...I heard it again and it seemed louder...
later...it went away again....and now it is back again..but again a little louder and now very easy to hear.
I am having a hard time to locate it precisely. At first I thought of the A/C pump...but since it is not ON, it cant be, I guess.
Now I am thinking of the power steering pump...
the noise is not metal like, but more plastic...like when you hit something plastic with something hard...and it is not constant with the rpm of the engine...it's more like....
tik....tik......................tiktiktik..........tik.......tik...........tik...tik...
okay, this might sound crazy....but its allmost as if I would have dropped a small coin in the power steering pump...although I have no idea how the inside of this pump looks like....
do you guys have any pointers or ideas of how to investigate this?
(sorry for my bad english, I am dutch)...
kikkegek is offline   Reply With Quote
Old 03-09-2011, 08:39 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Rattling sound driver side of the engine, please help!
i've used a cut off broom stick ,carefully place in on stuff you wana check and the other end up to your ear....dosn't have to fit lol
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-10-2011, 04:01 AM   #3
kikkegek
kikkegek's Avatar
like before, the ratteling now has misteriously again gone away...just waiting for it now to come back...thanks for the reply hough Motornut
Old 03-11-2011, 08:23 AM   #4
BigBlocksRule
Sounds like an exhaust manifold leak, the "tick" sound made by this kind of leak sounds just like a metal on metal tick. Check your bolts.
Mechanical noise making stuff generally doesn't go away by itself...when it does, it generally comes back with a vengeance!
BigBlocksRule is offline   Reply With Quote
Old 03-17-2011, 05:04 PM   #5
ratsub
Hey Kikkegek,
I have the same kind of sound and it seems like it's the powersteering pump.
It's only there, when the hood is raised (and the motor is running)
Problem of Dutch Subs?
Gr. Mark
ratsub is offline   Reply With Quote
Old 03-17-2011, 05:17 PM   #6
kikkegek
kikkegek's Avatar
Originally Posted by ratsub View Post
Hey Kikkegek,
Gr. Mark
I read your post on the dutch forum. dont know, havent figured out mine yet. did you?
Old 03-17-2011, 11:24 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
do you have an air pump?
maybe, can you remove the pulley belt and then try it
John
Old 03-18-2011, 01:37 AM   #8
ratsub
Not yet, but I will soon.
I'll let you know.
Gr. Mark
