Old 03-06-2011, 08:43 PM   #1
Conundrum
Conundrum's Avatar
Bed Bolts
Where is the best place to buy bed bolts from?
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 03-06-2011, 08:47 PM   #2
tucsonjwt
Re: Bed Bolts
If you are lucky - junkyard. LMC has them. I would try to get the GM part number and check with the OEM sellers on the net also. Different years take different length bolts.
tucsonjwt is offline   Reply With Quote
Old 03-06-2011, 09:00 PM   #3
Conundrum
Conundrum's Avatar
Re: Bed Bolts
Mine is a 74, and anything 73-80 is hard to find in the junkyards close to me.
LMC is probably where i'll go.
Old 03-06-2011, 10:02 PM   #4
tucsonjwt
Re: Bed Bolts
You might as well check the usual suspects while you are at it: Classic Parts, Rock Auto, even Ebay, etc.
Old 03-07-2011, 12:42 AM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Bed Bolts
Carrier bolts work. Carrier bolts are easy to find at any hardware store.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 03-07-2011, 12:45 AM   #6
codydubb
codydubb's Avatar
Re: Bed Bolts
Got mine at IPACO HUGE Hardware store
1985 Chevy C10
350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker
codydubb is offline   Reply With Quote
Old 03-07-2011, 09:15 PM   #7
Conundrum
Conundrum's Avatar
Re: Bed Bolts
So what length of carriage bolts do I need for a 74?
Old 03-07-2011, 09:22 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Bed Bolts
I just dropped some long bolts in the holes till I got a length I wanted, then went to the store?
John
1999 Toyota Tacoma 4x4
Old 03-07-2011, 10:35 PM   #9
1986swb
1986swb's Avatar
Re: Bed Bolts
I got mine from Classic Parts of America as a set. They offered the bed bolts in stainless, chrome, or zinc bolts. I went with the stainless. You can also try Lowes for one offs. They have zinc and stainless. Be careful when removing the original bolts especially if the are a little rusted. Use a manual socket wrench and lots of loosening lube. If you use an impact wrench you risk stripping the bed holes as the rusted bolts will tear and spin in your bed. This is from experience. Others may have suggestions as well.
1986 GMC Sierra Classic C1500 SWB
2006 GMC Yukon Denali
http://67-72chevytrucks.com/vboard/a...hp?albumid=977
1986swb is offline   Reply With Quote
Old 03-07-2011, 10:58 PM   #10
1LowToy
Re: Bed Bolts
When loosening them on a wood bed I'd hold them from underneath withvice grips or a pipe wrench. They will spin and break the wood in the bed. Don't ask me how I know I'm still trying to cry out $300 from my wife for new wood.
1LowToy is offline   Reply With Quote
Old 03-07-2011, 11:04 PM   #11
1986swb
1986swb's Avatar
Re: Bed Bolts
Ouch. Sorry to hear about your wood bed. I feel your pain. My bed is metal so only two holes got messed up but I was able to remedy the issue with a couple of hex heads.
Old 03-08-2011, 07:40 AM   #12
Conundrum
Conundrum's Avatar
Re: Bed Bolts
I don't have any bolts at the moment, my truck came without a bed and I found one for it.
Old 03-08-2011, 02:51 PM   #13
hlp-3
Re: Bed Bolts
Not 100% sure about your 74, but I just had the bed off of my 85 and the bolts were 1/2-13 x 4" with a little dog point making the overall length 4 1/4". 4" will get it done or 4 1/2" if you want a little insurance. I am assuming the 73' - 87' are the same.
________________
2007 Trailblazer SS
1996 Corvette (sold)
1987 Silverado LWB (R20)
1985 Silverado SWB (C10)
1973 Nova SS
1965 Chevy C-10 SWB (sold)
hlp-3 is offline   Reply With Quote
Old 03-08-2011, 03:21 PM   #14
bigblock73
yeller
bigblock73's Avatar
Re: Bed Bolts
Hardware store carriage bolts will likely not fit, the "square" will be a different size and won't work.
bigblock73 is offline   Reply With Quote
Old 03-08-2011, 04:26 PM   #15
allengator
allengator's Avatar
Re: Bed Bolts
its a better deal at LMC to buy the whole body mount kit... core support mounts (2) cab mounts (4) and the bed bolts....
IF you need those things anyway!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 03-08-2011, 05:08 PM   #16
Prerunner1982
Prerunner1982's Avatar
Re: Bed Bolts
Hardware store carriage bolts worked fine on my 82 long wide bed. On the long bed there are 8 bolts, 6 are the same and the other 2 are very long. I didn't guess the long ones right, but figured 6 out of 8 should be fine.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-08-2011, 05:26 PM   #17
Jonboy
Slots go on anything!
Re: Bed Bolts
After that, go to the hardware store and get a stack of body washers, too. My LMC core support mounts were almost 3/4" too short. Just FYI.
The bed bolt set is pretty cheap, though. IIRC is is about $20.
1974 Jimmy- 5.3/4L80e/NP241
Old 03-08-2011, 11:13 PM   #18
tucsonjwt
Re: Bed Bolts
So, here is the deal - You have a 74 truck but what year was the donor truck?
I got a 76 bed from a junkyard to install on my 73 longbed, but the bolt holes were not in the same location on both trucks, and the length of the bolts was also different. As I recall, there were two bolts in a different location, which required drilling through the frame in the new location of the bolt holes. Fortunately, I had a crap 73 and the junkyard drilled the holes for me and gave me "free" bolts with my $400 used box.
Old 03-08-2011, 11:45 PM   #19
broey
Square
broey's Avatar
Re: Bed Bolts
Just get carrier bolts from home depot.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 03-09-2011, 12:17 AM   #20
Altec
Getcha Pull
Altec's Avatar
Re: Bed Bolts
Do you have to have the original bolts? I always replace them with simple hex head grade-8's. Just because half the time the factories spin anyway... My current K10 is getting regular bolts, and I'm going to weld the nuts to the frame. I don't feel like dealing with having to hold 2x4 on the bolt head while having someone crawl under the truck to try and loosen the bolts.
Have you tried Mcmaster-Carr? Under Screws & Bolts > Specialty Bolts. Might have something.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
