Installed my Glorified Holley Last Night
Recieved my Demon 750 the other day and finally got the time to throw her on last night and take her for a spin....She runs like a CHAMP! No leaks no problems! Love the hell out of it!!! Still think im in need of some bigger heads but it runs alot better than that old 650 Holley did.
1985 Chevy C10 ![]() 350 .60 over iron eagle h-beam rods, sealed power high comp pistons, forged crank, vortec heads, edelbrock performer rpm vortec intake, roller rockers, .488 .510 cam 750 Demon Double Pumper, Longtube headers, Dual Flowmaster exhaust,Dual electric fans, Proform electric water pump. TCI 3500 Stall Converter th350 trans B&M shift kit 10 bolt 3.73 Detroit Locker |
Re: Installed my Glorified Holley Last Night
Awesome! Glad to hear it
GUULLPP
84 K20 Long Box W.I.P ![]() 78 Burb - parts now [Rolled] ![]() 68 c20 dump bed ![]() WHEN IN DOUBT--- FLOOR IT ![]() |
#4 | |
one belt??
mine has like 5 stock carb an like 500 lines running all oner the place. looks good enjoy it when its time think im gona get an ebrock |
Its got 2 belts. Mine did at first when i got it too bet i pulled out 5 pounds of wiring- it used to be tbi way back when, one of my next projects is getting rid of that a/c box!
howd you go about getting rid of all the mess?
how do i know what i need and dont need? my truck has ac. but i never use it. that will eventually be going too guess i need to get the carb, and intake mani, then i can loose some of the extra mess. thanks and good luck with truck |
I just got a wiring diagram of the truck and traced down what i needed and what i didnt need, getting rid of your tbi distributor and manifold would be step 1 then eliminating wires will come pretty easy after that
Is it a Speed Demon or a Mighty Demon ??? and what kind of brackets are you using with the Elec H20 Pump???
Its a Speed Demon. Its a Proform water pump the bracket setup is from Marsh Performance thought it was gonna be a cheap conversion come to find out i had to buy the $175 Marsh alternator bracket adapter. Summit told me i would have to buy an additional bracket adapter for the powersteering pump but with a little modification and ingenuity i got my pump to mount and line up just perfect. you can get both bracket adapters for $300 for a set i believe, but will need the alternator one for sure well worth the money to figure it out on your own though
have fun.. i hope you never backfire thru the carb.
Don't have to worry aout that with a demon. I love my 650 speed demon on my 361 sbc. Fires right up and doesn't have to be tuned every other day!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#13 | |
#14 |
he is just thinkin of old holleys. When they backfire through the carb, they blow out the power valve... And thats still not a big deal.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
#15 | ||
anyway, I have personally run demons of all sizes,625 road demon on a stock crate 350,650 road demon on a built 355, a 750 speed demon on a mild 454 an my pops had a pair of boost referenced 850 mighty demons on his blown 540 bbc. I have NEVER seen another carb that is so finicky and hard to tune much less reliable in my life. When I worked for summit racing, we quit carrying demon because 80% of them came back to us. I have holleys or QFT carbs on my vehicles now. |
#16 | |
