Need help / dual fans
Hello guys
Yesturday I bought some dual fans at a swap meet my problem is how Do you wire them together? so they both come on when I hit the toggle switch PICTURES PLZ if you have them Thank you Jeff M ![]() ![]() |
Re: Need help / dual fans
I wired mine separatley with a relay (75 amp) and a diode for each. I then installed a continious duty cycle solenoid and ran both to that. Dual fans pull a lot of juice on start up.
You can buy a kit at any auto parts store that has averything you need for about $40. I am doing the same thing to my truck.
Yep, a solenoid for each Fan
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
this is what I used, but make sure you use a Maxi-fuse
http://www.oreillyauto.com/site/c/de...1388&ppt=C0331
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Parts and more parts
I used to run mine in a setup where they both came on at the same time, but that worked my alternator more than I wanted it to. It also made my headlights dim at stoplights. I purchased a dual fan controller from SPAL and then an extra fan relay to support the heavy duty fans. There are other outlets out there that do the same thing.
My fans cycle on one at a time (starting at slow speed and increaing as the heat load is increased) and if the heat load is large enough, then both fans can run to support the load. Look at the following websites www.centechwire.com www.spalusa.com
Frank |
BAD BOW-Silverado XST
Wire them seperately. Use a fuse for each one. Tie them together only by their relay connections. Use the on wire to fire both relays. Each fan should have its own power and ground. I even have a fusible link wire at the battery connection.
