Oil Sender
Ok i bought the stock oil sender and its kinda big to fit right there by the distributer. Where else could it be put out of the way ( 82 K20 350 )
2004 Silverado Crewcab (Dark Spiral Gray) |
One shot, one kill.
Re: Oil Sender
Big, the sender you got is for guages. If you have idiot lights it won't work. Look down by the oil filter, thats where the sender goes with guages. Depending on application, the sender by the dist is probably for an electric choke heater. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
Re: Oil Sender
This where they P.O. had the cheapy mechanical gauge hooked to, BTW, i do have gauges and I am trying to hook them back up, I will surely look by the oil filter and see if it will go there. Thanks
Re: Oil Sender
have same kinda issue.
my guage was reading real low. someone suggested changing the sending unit. so i did this....and its still eading the same. doesnt seem to move??? |
Re: Oil Sender
chevrolets show low oil pressure at idle anyways
Re: Oil Sender
you can get a angled fitting that will put the sender away from the distibuter it 45s away from it.
84 K20 Long Box W.I.P ![]() 78 Burb - parts now [Rolled] ![]() 68 c20 dump bed ![]() WHEN IN DOUBT--- FLOOR IT ![]() |
Re: Oil Sender
Hopefully I wont have to if I can put the sender near the oil filter
Re: Oil Sender
Went through this when I first got this C-30. Agree that there wasn't enough clearance so opted for this solution in brass. One straight and one 45 degree fitting and it worked.
![]() Still recall it was not easy with so little room to even turn a wrench and yes it just barely clears the distributor...but it did and that is all that matters. ![]() Mark ![]()
1985 Chevy C-30 Hydraulic Dump Bed 2001 Saturn SC2 (go to work car) 2010 PT Cruiser (wife's car) "Reality is just a hallucination brought on by lack of alcohol." ![]() |
Re: Oil Sender
My sender is a bit bigger than that. And the book showed the same sender for the 350 and the original Diesel motor
Re: Oil Sender
My 86 sender was smaller. 6.00 at o'reillys fit with hei
Posted via Mobile Device |
Re: Oil Sender
