03-19-2003, 01:57 AM | #1 |
blinker in dash stays on
Whenever I turn my lights on the left blinker indicator in the dash comes on but it shines real dim. When you turn the blinker on it goes out and the blinker functions normally. Turn it off and the light is on again. Where do I start?
Andrew
'67 Chevy Longbed Fleetside - Daily Driver(For Now) '72 Cheyene Longbed Fleetside-Daily Driver Best Towing Service |
03-19-2003, 02:03 AM | #2 |
Location: Bondurant, IA but in Worcester, MA for school
Same thing is happening to me except with my right blinker. I think it might have something to do with a bad ground but i dont know cus I havnt had time to look at it. Let me knoe if you find anything out please.
HotRod
1970 Chevy C-20 350 V-8 Turbo 350 w/ shift kit Dana 60 w/ 4.10 gears AND Powr-Loc POSI New Additions: Summit Headers 135amp alternator Proform HEI Edelbrock 1406 600cfm carb Sunpro Tach Powr-Loc POSI Edelbrock Performer RPM Intake MSD 6A Ignition Box AIM: HotRod929 Visit My Site: http://1970chevy.netfirms.com/ |
03-19-2003, 02:52 AM | #3 |
newly minted old timer
yep somehthing is grounding.. prob in the buld connector.. take the bulb out and look at it..lol
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
03-19-2003, 06:57 AM | #4 |
IMO you need a better ground on the front park lights. I had the same problem. I used a short piece of wire and a couple of stake-ons and ran a ground wire from one of the bolts that holds the park light in place over to the radiator support. Havn't had any problems since.
"The World's a Mess"! 71 C-10 72 Suburban 2WD Oceana, West Virginia |
03-19-2003, 07:11 AM | #5 |
English Chevy Owner
Check your floor mounted dimmer switch. They tend t get wet a corrode and cause all sorts of dash related electrical problems. Clean up the mounting area on the floor for it and replace it if it is looking ropey.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
03-19-2003, 09:09 AM | #6 |
You've got a ground problem for sure......mine was doing the same thing, left turn signal.
After a total run down of the entire system, under the dash and the hood. finally found the positive cable was almost burnt in half...... Good luck, tracing these are hard work.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
03-19-2003, 10:00 AM | #7 |
blinker light
check your bulbs. one of the filaments in a bulb is making contact on the park ligh filamentin that bulb. had this happen before.
troy wilson |
03-19-2003, 12:12 PM | #8 |
Spank 'em if you got 'em!
I'm sure I will have this problem soon. I noticed the other day that i can see all the wires going to the rear through the vent holes (thanks to the rust fairy) in my rockers. Only a matter of time before some big chunk of something falls off and trys to take the wiring with it.
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
03-19-2003, 11:10 PM | #9 |
i have the same prob with this but on the right side, i have good grounds but am going to rewire the whole truck soon so i am going to deal with it for the time being and also when i turn on my brights i loose my dash lights, do you guys have that prob?
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
03-22-2003, 02:03 PM | #10 |
I noticed the other night when I was following somebody that I could see my parking light in their bumper but the blinker wasn't working. I checked the bulb and it looked ok, but I replaced it anyway and the light doesn't satay on anymore.
Thanks, Andrew
03-23-2003, 01:53 AM | #11 |
its all about the +6 inches
71Custom hit the nail on the head.
When this happens, the first thing to look at is your turn signal bulbs. This i the way GM used to set them up to inform you there is a bulb burned out. |
03-23-2003, 06:06 AM | #12 |
blinker
i must be invisable on here. duh............. read my post. maybe i'll just let everyone figure out there own problems from here out. if anyone would like to know how this happens, ask and i'll explain it. by the way when you have a turn signal bulb burnt out it will not flash at all at the dash indicater. i can explain this also no gm didn't desiegn this ether, the flasher manufacturer did and it is this way in almost all older cars and trucks.
troy wilson |
03-23-2003, 09:09 AM | #13 |
Black 72 Chevy
Check your grounds. I had this problem with my right blinker. There wasn't good ground on my front blinker on the bumper.
03-23-2003, 01:53 PM | #14 |
Troy, i was just adding to your responce. The filaments do not need to be touching in order to cause his. You can remove a bulb all together and it will cause the same fault.
I was unsure that anyone else did this too. Good to know info. |
03-23-2003, 05:51 PM | #15 |
blinker
sorry longhorn, i was to quick to jump. just ain't been a good week. blood sugar is up- got the flu- and some dumb a$$ calls at 1:30 in the morning. wouldn't be so bad, but sincei didn't answer first time she does it 5 more times. finaly get out of bed, expecting maybe one of my family is hurt - i get "is john there"? no john here. might as well stay up now. 2:30- again "is john there"--no its still the wrong number. oh, sorry- yea so am i. i get up early, but thats to early. bad part of being in a 24 hr. town i guess. sorry guy
troy wilson |
03-24-2003, 12:00 AM | #16 |
no problem man.
