Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-10-2011, 05:22 PM   #1
cweber
454 Question
So a buddy is tearing down his mud bogger and is wanting to sell me his 454. Its stock and runs but has recently develped a knock, so he is going back to his 350. He only wants $75 bucks for the complete motor minus the carb and distributor. My question is how hard and expensive is it to get about 500-600 horse from this motor? It doesnt sound like its that difficult to get 1hp/1ci from what i have seen. Any thoughts or suggestions?
cweber is offline   Reply With Quote
Old 03-10-2011, 07:56 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 454 Question
Yes, it is not too difficult to reach 500 bhp from a BBC. But, in your case, I would have the block thoroughly checked. Good luck.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-10-2011, 10:07 PM   #3
PGSigns
PGSigns's Avatar
Re: 454 Question
How hard and how expensive it is to 500 or 600 greatly depends on what you are starting with. Getting 500 is a lot easier than 600 out of a 454. Any ideas of what is in the motor he wants to sell you and how much water and dirt has been through it?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-11-2011, 08:48 AM   #4
djracer
djracer's Avatar
Re: 454 Question
Try to get the casting numbers off the heads and block. If you can find out if it has a cast or steal crank?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-11-2011, 10:51 AM   #5
cweber
Re: 454 Question
I dont think its had any water or dirt in it, but Im sure some could have made its way in. Its just a bone stock from a 70s or 80s truck. I think I may have decided against it. I havnt even put 600 miles on my 350, and have enough trouble keeping the tires stuck to the ground.
Old 03-11-2011, 01:27 PM   #6
dougminton
dougminton's Avatar
Re: 454 Question
Go big block. Always go big block.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 03-14-2011, 04:16 PM   #7
cweber
Re: 454 Question
So I told the guy no and now I have a big block in my shed. The research begins!
