Old 03-13-2011, 02:46 AM   #1
masaki
about camaro engine... for my jimmy
Hi, I found a camaro engine here I want to use this engine in my gmc jimmy 73 (4x4) but, I don't know if this engine is compatible with my muncie bell.
I want to know too, what do you think aboutthis engine? is a good choice?
My truck:
GMC Jmmy 1973 sierra
Original engine (gone) Chevy V8 350 carburated
Gear: Muncie + NP 205
Engine found
Chevy camaro 1997 V8 350 LT1 Multi port fuel injected electronic controled
1988 Ford taurus LX SW
V6 3.0L vulcan - Axod
1973 GMC Jimmy Sierra 4x4
L6 diesel nissan LD28 (temporal engine)
masaki is offline   Reply With Quote
Old 03-13-2011, 11:34 AM   #2
Zoomad75
K5Camper
Zoomad75's Avatar
Re: about camaro engine... for my jimmy
All small block bell housing mounts are the same gen 1 and 2. The LT1 is a Gen 2 design. Outside of the heads and cooling flow difference, a LT1 will bolt right in and work. However, LT1's cooling system is a reverse flow compared to the standard small block setup, so you'll have to adjust for that. Plus going with the fuel injection will require adapting a computer and harness to your truck plus and upgrade to the fuel system with an electric pump and high pressure lines.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-13-2011, 05:10 PM   #3
masaki
The engine is with the harness and ECU, what modification I need to do for the reverse cooling system? I want to put an electric fan too
Old 03-14-2011, 08:01 AM   #4
tobiahr
tobiahr's Avatar
for the reverse flow coolant you need to make sure you have the radiator connected so the flow goes from top to bottom (in on top , out on bottom) and the water pump is what came with the engine (reverse flow). for the electric fan just make sure you get one rated for the engine/radiator size and you should be ok
tobiahr is offline   Reply With Quote
