Old 03-14-2011, 03:32 PM   #1
KrazyRay
KrazyRay's Avatar
Parting 72 GMC SIERRA 1500 2WD
I have a GMC that is going to be parted this week. The sheet metal is rusted and no good, the cab is rusted, the seat is junk, and the vent windows are dinged up. The radio is sold. The back end will be made into a trailer. I will give 2 days from the time I answer a question on a part and then it goes to next in line. Paypal and MO is good and I usually ship out on Fridays. Please respond in thread to avoid confusion.
Thanks, Ray
front disc brake setup- $150 local
cargo light- $35 shipped SOLD
dual horns with wire- $32 shipped
Sierra 1500 fender emblems- $26 shipped pair
2 barrel carb- $30 shipped
distributor- $22 shipped
power steering pump, brackets, box, hoses- $100 plus shipping SOLD
exhaust manifolds- $60 plus shipping
brake booster, brackets, prop valve- $50 plus shipping SOLD...I have another one
auto steering column- $50 plus shipping
AT cross member- $25 plus shipping
jack- $30 shipped
driver side head light bezel- $22 shipped
grill support- $10 plus shipping
smog cannister- $15 plus shipping
engine bay wiring harness (headlights) not carved up- $25 plus shipping
headlight rings- $10 plus shipping
7 blade fan- $15 plus shipping SOLD
front cab support frame brackets- $26 shipped pair
deluxe front side marker lenses- $16 shipped pair
vent windows- $25 plus shipping pair (not show truck)
I'm going to try to test fire the engine/trans today to see if there is any hope for them.
KrazyRay is offline   Reply With Quote
Old 03-14-2011, 03:37 PM   #2
hector68
Re: Parting 72 GMC SIERRA 1500 2WD
interested in the power brake booster. pending on pics thanks
hector68 is offline   Reply With Quote
Old 03-14-2011, 03:38 PM   #3
hector68
and brackets also sorry. shipped to 77521 pending on pics
Old 03-14-2011, 03:44 PM   #4
KrazyRay
KrazyRay's Avatar
pics
Old 03-14-2011, 03:58 PM   #5
KrazyRay
KrazyRay's Avatar
more
Old 03-14-2011, 04:05 PM   #6
jays68yak
jays68yak's Avatar
how badly rusted is the floor and lower part of the firewall? I need some patch panels.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds.
1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s
1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig
"I like long walks, especially when they are taken by people who annoy me. "
jays68yak is offline   Reply With Quote
Old 03-14-2011, 04:08 PM   #7
KrazyRay
KrazyRay's Avatar
The booster, etc is $75 shipped tp TX.
Thanks, Ray
Old 03-14-2011, 04:11 PM   #8
KrazyRay
KrazyRay's Avatar
I have a few cabs that will take care of your patch panel needs.
Thanks, Ray
Old 03-14-2011, 04:23 PM   #9
jays68yak
jays68yak's Avatar
Thanks, Ray
sweet Ill send you some pics later on to see what you can do for me.
Old 03-14-2011, 04:27 PM   #10
JORGIE95961
how bad is the dirvers side of the rad support and how much for local pickup?
JORGIE95961 is offline   Reply With Quote
Old 03-14-2011, 04:31 PM   #11
missinfishin10
Amazed Member
missinfishin10's Avatar
I'll take the 2 SIERRA emblems.
71 LWB Fleetside
1950 3100 Original Project!
missinfishin10 is offline   Reply With Quote
Old 03-14-2011, 04:35 PM   #12
fwells67
interested in the glove box door and the gas pedal and bracket. could you post a pic.
fwells67 is offline   Reply With Quote
Old 03-14-2011, 04:38 PM   #13
dozerman
How bad is the bed rusted?
dozerman is offline   Reply With Quote
Old 03-14-2011, 04:40 PM   #14
dan s
dan s's Avatar
I am interested in the upper body side trim,upper taigate trim as well as cab paint divider trim pending price shipped and some pics. Thanks Dan.
dan s is offline   Reply With Quote
Old 03-14-2011, 04:47 PM   #15
JORGIE95961
i think hes using the bed for a trailer
Old 03-14-2011, 05:48 PM   #16
sjarrett71
sjarrett71's Avatar
If it's a TH400 trans, how much for the kickdown switch with all the wiring? I don't need the pedal assy, just the switch and complete wiring. Shipped to Rolla, MO 65401?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 03-14-2011, 06:21 PM   #17
72Much
I need the brake booster to firewall bracket and linkage to 38059.
72Much is offline   Reply With Quote
Old 03-14-2011, 06:42 PM   #18
72gmcer
How much for the steering box and pitman arm separate?
72gmcer is offline   Reply With Quote
Old 03-14-2011, 08:11 PM   #19
KrazyRay
KrazyRay's Avatar
JORGIE95961- The support has heavy rust, but not rusted through $60 to your door
missinfishin10- I will pull and make sure the studs are good.
fwells67- gas pedal assembly with cable and carb bracket, and glove box lid $50 shipped
dozerman- I have a nice long bed with great floor $350
dan s- Do you need fender spears, door trim, and bed trim?
sjarrett71- It looks to have kickdown switch, but its a th350...I will check further.
72Much- I have some loose brackets with linkage $38 shipped (if you don't need booster)
72 gmcer- $62 shipped for ps box with pitman.
I will post more pics as I pull parts.
Thanks,
Ray
Old 03-14-2011, 08:16 PM   #20
68lowburb
68lowburb's Avatar
how much for water pump pulley and crank pulleies shipped to 70737 thanks jimmy
68lowburb is offline   Reply With Quote
Old 03-14-2011, 08:23 PM   #21
dan s
dan s's Avatar
Ray,yes I need all of that plus the small pieces behind the doors on the cab. Thanks Dan
Old 03-14-2011, 08:26 PM   #22
fwells67
i will take it . gas pedal with bracket, cable and carb bracket and glove box. could you post a pic of the front of the glove box and the gas pedal.thanks
Old 03-14-2011, 08:27 PM   #23
ewoody625
ewoody625's Avatar
Ray
I need a patch for the driver side cab corner up to just below the door latch the whole section. I can get a pic if needed. how much shipped to 46383 if you have one?
Eric
Eric
70 CST10 long bed in pieces also factory air and cruise(the project)
18 Silverado crew cab 5.3 4x4
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166
ewoody625 is offline   Reply With Quote
Old 03-14-2011, 08:49 PM   #24
sjarrett71
sjarrett71's Avatar
Also how are the window regulators?
-Scott-
Old 03-14-2011, 08:56 PM   #25
otsenre
otsenre's Avatar
Cargo lamp if not pitted
otsenre is offline   Reply With Quote
