03-15-2011, 10:35 PM | #1 |
2000 burb frame under 1972 burb body?
Anybody ever do this combination. I want to put a late model engine in my 72burb but thought that swapping the frame might be better (ride, abs, ease of use of trans, exhaust, etc...). I know the wheelbase will have to be shortened but did not know about if there were any width issues etc... I also posted this in the suspension section but since it is burb specific I thought I might get a better response here.
03-15-2011, 11:11 PM | #2 |
Re: 2000 burb frame under 1972 burb body?
A member named Jeffg1010 has something like this.
1973 IH Scout 1977 Ford Bronco 1999 Ford F-250 SD XLT 4x4 2000 Chevrolet Tahoe LS 4x4 1967 Chevrolet CST C/10 LWB 2WD 1970 Chevrolet Suburban 4x4 |
03-15-2011, 11:26 PM | #3 |
What?
I don't have any first hand experience.
Though there is a guy running around my town with a 66 burb that has a 2000 vintage chassis under it, along with the Duramax, trans, and transfer case. I briefly spoke to him about it, and he said that it came from a quad cab pick up and that the frame was shortened in the middle. The rig is a looker, and is always in the local shows and parades.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 03-16-2011 at 11:15 AM. |
03-16-2011, 02:45 AM | #4 |
make it easy on yourself....just graft the front cross member in and weld some perches to the y2k rear axle so it will bolt up the 72 trailing arms.
03-16-2011, 09:37 AM | #5 |
I have a K10 and it seems to me that grafting the front end in would be no more difficult than cutting 3 inches out of the middle. I am assuming that the frame has roughly the same width and I know what happens when I assume. I have the opportunity to get a 2000 Suburban 1500 4wd cheaply so I would have all of the components needed.
03-16-2011, 11:09 AM | #6 |
C10 Club Tennessee
I'd be interested in seeing this, I live just up the road from you in White House.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
03-16-2011, 01:42 PM | #7 | |
03-16-2011, 07:28 PM | #8 |
Seems like it would be far easier to swap the engine and trans into your frame than the whole frame, or even the subframe.
1969 C10 Suburban 350 1963 Falcon gasser 464 BBC 1946 Austin 327 SBC gasser |
03-16-2011, 10:36 PM | #9 |
I'm in the market for a 3/4 ton late model 4x4 with a duramax. I plan to do exactly what you're talking about. It shouldn't be too hard. If you can weld in a new crossmember and rear axle then it shouldn't be too much harder to fab new body mounts. Plus the newer frame is stronger and all the geometry is made to fit the frame, plus you benefit from 30 more years of engineering advancements in suspension, braking and ride quality.
