Can I have some Step notch pics/help?
Im going to be installing a step notch I got from QAR(suicidedoors). Well yesterday, I tacked one side together to see what it will look like and I kinda got nervous about what I'm about to do. What I think I'm going to do is knock it back loose and tack the sides to the frame and tack it together like that and see how it looks. Can someone post up some installation pictures or just some good pics for me to get a better idea? It's going on a 67 swb stepper too btw. Any help or advice will be greatly appreciated.
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
Re: Can I have some Step notch pics/help?
Can someone just point me toward a thread maybe? I know someone has some knowledge about step notches.
ask and you shall recieve-----------------------http://67-72chevytrucks.com/vboard/showthread.php?t=393867
Here is the KP notch in a 67-72. Not sure what year you are building.
http://67-72chevytrucks.com/vboard/s...d.php?t=188332 ![]() ![]() ![]() Always loved this truck: ![]()
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
![]() Posted via Mobile Device |
When I install the step, where am I supposed to position it on the frame? I mean is the top of the step supposed to be centered on the axel? Is the truck supposed to be at ride height or dropped when I install it? Stuff like that is where my problems are. Thanks for the pictures too.
67cheby
![]() Join Date: Sep 2008
mine is from suicide doors i did like you were doing tacked it together and set in on and finished it up
67cheby
and a few more, i added a little support in front of the notch, i boxed the frame a little
Thanks 67chevy, what are or did you put back in place of those cross sections you had to cut out to fit the notch? Or do you not need anything due to the cross section between the notches?
67cheby
here are some pics
Wow, that looks a little complicated. Thanks though man, I'm going to check out your thread. That's what I was hoping this thread would do, bring some people in with build threads I can check out. Thanks again man, I really appreciate it.
#13 |
Oh yeah, I also think I'm going to make a install for the FAQ. Just hope I don't mess up!
#14 |
I too am just about to fitt a step notch,
My thoughts are; measure the small arc from the front center mounting bolt of the rear controll bars, (main link from crossmember to axle) and add diameter of axle + 1" either side for clearance, put this middle bottemed out dimension in the center of your c notch, ?? ore have i got it wrong,?? |
#15 |
I was hoping to attract some people who have done this and put it in thee build thread, so far only 67chevy has posted.
#16 |
Im not quite following you bud, lol that's why I need help myself though!
#17 |
Most people center the notch over the axle. But you have a few things to consider first. do you have a 4 link, stock truck arms , or stock leaf springs ?.
a 4 link will keep the axle pretty close to center most of the time as well as a leaf spring ( mono leaf + blocks) however the truck arms will move the axle back when lowered untill parallel with the frame then forward after parallel of the frame rails,. so do you want the axle centered when driving or when dropped or both? thats the difference between a truck and a show truck. you can see on the black truck the wheels are shifted forward a bit when laid out. so do you care or not. some people move the truck arm crossmember to accomodate their axle position. either way its your call but once you weld the notch in, the axle should be centered above the location you chose...
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#18 |
fat old dude
![]() Join Date: Feb 2010
nice looking notches.
1972 c-10 shortbed 350/400 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157 1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216 Accepting part donations |
#19 |
wish my truck looked like that black one or 67chebys they are both awesome looking! , guess i should go work on my rust....
#20 |
67cheby
....just so you know....i have been working on mine for 8 years.............so dont envy me to much
#21 |
__________________ i know it 67cheby ive been watching you... ive had 2 bagged late model trucks one sold before the wedding the other i just got tired of it,(i didnt build it) and i always wanted a 67 , finally found one i could do something with and it sat for 5 years untill a few months ago. im old enough to have patience and do alot of work myself. now if i could just find a 62 impala to add to the collection , "honey we need to add a garage onto the new house" hahahahahahaha
#22 |
67cheby
how about a 63 ?
#23 |
Man you are a car salesman.
#24 |
67cheby
Lol....i try !!! 59 is my favorite
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 04-18-2011 at 06:01 PM. |
Tags |
install, notch, step, step notch install |
