03-21-2011, 05:41 PM | #1 |
Tach dash mods(something other then a factory tach)
So I have decided that I need to add a tach to my dash(this is in addition to the long list of mods I am already doing!)
I thought about locating a factory tach for my dash but want to do something unique. To be honest, I don't need the tach front and center as I don't need to look at it every 5 seconds(it's not a race car) but I do want to be able to see what I am turning for rpm's when highway driving, etc. I took a look at my dash and decided I can lose the clock and fit a 2 1/16 tach in the hole. I found a gauge that has a very similar numbering on the face. The real trick will be to cut up the gauge once I get it so I can remove the bezel and glass and utilize the factory lighting to light the face of the dial. Here is my current dash(with the clock hanging out) and the gauge I am looking to purchase. What have you guys done for custom tach mods? Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
03-21-2011, 05:53 PM | #2 |
Re: Tach dash mods(something other then a factory tach)
do a search for the Camaro tach mod.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
03-21-2011, 06:06 PM | #3 |
Getcha Pull
It would be easier to grind out the inside of the plastic gauge housing, and using PVC tubing cut and angle it to hold the gauge, and set it at the same depth and angle as the factory. Then epoxy the PVC to the plastic housing. Assemble, and enjoy. All you should need is a dremel, epoxy, and PVC. Maybe a strip of aluminum to make a new clamp to hold the gauge in. Something in a Z shape to go out the back of the PVC and clamp the gauge to the back plastic housing. So the PVC tube is sandwiched.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
03-21-2011, 06:39 PM | #5 |
Slots go on anything!
We talked to the Dakota Digital folks this weekend at Goodguy's, and they will have their new analog style digital gauges out by the 4th quarter of this year. Their gauges were awesome. I just restored a tach cluster for my truck, and I am seriously thinking about pulling it out for one of their clusters after they come out. Everything is integrated, suck as check engine lights, turn signals, etc. Pricing is going to be in the $800 range, but an autometer swap isn't a whole lot cheaper.
1974 Jimmy- 5.3/4L80e/NP241 |
03-21-2011, 10:07 PM | #6 |
Happy to be here
Good luck with that. I have been hearing "in a few weeks" for a LONG time.
03-21-2011, 11:18 PM | #7 |
Here's what I did with mine. Found an older cluster on eBay that had a tach unit with a fuel gauge built in. It was out of an old 2-1/2 ton version that had a diesel. I sent it to Red Line Gauge Works to be re-done - they re-did the face & internals to match my LS motor. Really liked the fuel gauge on the tach because it allowed me to keep the clock in it's usual spot on the cluster.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
03-21-2011, 11:27 PM | #8 | |
Posted via Mobile Device |
03-22-2011, 12:02 AM | #9 |
BMW & ASE Master Certified
They did a real sweet job on the cluster My4by2... I just sent them an email... Im in the process of fitting a Mercury Cougar 7000 rpm tach in the Fuel gauge location.
So far Ive: Bench tested the tach and it works fine Removed the fuel gauge and transfered it to a spare oil psi gauge face Secured the tach guts to the Fuel gauge face Tomarrow I will trim the Cougars tach face plate to fit inside the Fuel gauge face... I made in template in Autocad so I can make a nice cut so just incase the gauge resto service costs too much... I'll take a photo and add my project to the thread tomarrow. clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
03-22-2011, 04:07 AM | #10 |
502ss, good luck with that, im curious to see the outcome...
SSgt R Trujillo Jr ~ USAF '86 GMC Short Wide Box |
03-22-2011, 04:10 PM | #11 |
There will be pictures! Gauge is ordered, should be here in 2 days and then the fun begins!
03-22-2011, 09:41 PM | #12 |
Heres what I have going on...
The face of the gauge isnt going to match, obviously, but the OE needle fits the gauge just fine... it just doesnt reach the numbers so I just left it all Cougar parts. I called RedLine Gauges and thats a pricey option that Im not going to do... If I were to invest that kind of money, I would just invest in the CNC work to get the Dodge gauges mounted. Anyway, I got the tach calibrated to the original settings so I just need to scope out the factory tach and start changing the resolution to get the tach to operate correctly. clint
03-22-2011, 09:45 PM | #13 |
Yeah, Red Line isn't the cheapest way to go for sure.... It was the only way to get exactly what I wanted though so I took it. Like the tach you have though!
03-22-2011, 10:18 PM | #14 |
What do I need to get the factory tach to work with cruise control?
03-27-2011, 08:07 PM | #15 | |
