Old 03-22-2011, 02:07 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
How to identify column wiring?
Here are pics of some column wiring I have. Trying to identify if it goes in a std column, tilt, 4spd or auto....etc....anyone have a way to tell?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-22-2011, 04:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How to identify column wiring?
standard non tilt column.
Tilt would have a light on it with an added grey wire
Old 03-22-2011, 04:59 PM   #3
TomBennett
TomBennett's Avatar
On that note where does the grey light wire plug into?
TomBennett is offline   Reply With Quote
Old 03-22-2011, 05:36 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Thanks! Good to have all the experts on this board. Hope I can pass on the info I learn here someday
Old 03-22-2011, 08:14 PM   #5
JimKshortstep4x4
In the first picture of the switch there is a socket attached to the switch which makes the switch one that is used in a tilt column.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-22-2011, 09:32 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Jim
Is that where the bulb would mount?
Old 03-22-2011, 10:22 PM   #7
Longhorn Man
Jim! GREAT EYE!
I looked for the wire and saw nothing!
Jim is 100% right, that is a bulb holder, it is for a tilt.
On the other question on where to plug the wire for the light, it plugs into the fuse block, on the terminal labled cluster feed. This will control the light with the dash lights.
Old 03-22-2011, 10:37 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
So am I still missing the grey wire then? And where to find that bulb? I'll check my factory assembly manual to see if I can find out in there.
Is there a difference between 4spd and auto columns on the wiring?
Old 03-22-2011, 10:39 PM   #9
Longhorn Man
I'm not 100% positive, but I highly doubt there is though.
Old 03-23-2011, 12:46 AM   #10
70shortfleet
70shortfleet's Avatar
I don't know what that wiring harness goes to but it is not for a factory tilt column
70shortfleet is offline   Reply With Quote
Old 03-23-2011, 12:52 AM   #11
70shortfleet
I forgot to add that it's not for an automatic tilt column I don't know about a 4 speed tilt column
Old 03-23-2011, 01:50 AM   #12
VA72C10
VA72C10
VA72C10's Avatar
The plot thickens....
anyone that has taken these apart recently and has some pics that can verify what this may be from? Thanks!
Old 03-23-2011, 03:04 AM   #13
ls1nova71
ls1nova71's Avatar
That's not from a 67-72 truck column. Looks like either 66 or older truck or possibly a 68 or older car, Impala, Camaro ext.
ls1nova71 is offline   Reply With Quote
Old 03-27-2011, 11:50 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
Anyone that can verify that? I'm cornfused
Old 03-28-2011, 12:35 AM   #15
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Yes definitely not a 67-72 Looks to be 64-66 truck.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
