Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-22-2011, 09:55 PM   #1
1970C10truck
1970C10truck's Avatar
how wide can you go
Its time for new wheels and tires for my 70 c10. The truck is a project street and strip toy. I am curious how wide I can go in the rear on the stock width axle and trailing arms. I don't mind cutting the bed I just want to avoid narrowing the axle or any complicated suspension modifications at this time. Truck is stock height at this point but will probably end up with a 4 inch drop or something in the neighborhood.
1970 C10 swb 350 4spd under construction
1970C10truck is offline   Reply With Quote
Old 03-22-2011, 10:39 PM   #2
djracer
djracer's Avatar
Re: how wide can you go
you can put a huge tire under there you will just need a wheel with a ton of back spacing. I'm sure some one on here can tell you the actual width and wheel size. I know Hart Rod had a pretty big tire and wheel on his farm truck.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 03-22-2011, 11:24 PM   #3
stich626
mine are 295/50/15 on 10"
stich626 is offline   Reply With Quote
Old 03-23-2011, 12:22 AM   #4
1970C10truck
That's what I had on my last truck but it was a 78. I want to go bigger like in the 14" or maybe a little wider if possible. If anyone can post a setup with Wheel dimensions bigger than 295/50 on a 15" wheel I would like hear about it. I was looking at the wheel vintiques 15X14 rallys but the back space doesnt seem anything close to what I need.
Old 03-23-2011, 08:24 PM   #5
djracer
djracer's Avatar
I think you need like 7.5 inches of back spacing on a 12 inch wheel. I know you can fit a bigger tire than a 295/50/15.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-23-2011, 09:01 PM   #6
Robertjust777
what about the biggest on a step side without cutting the bed?
Robertjust777 is offline   Reply With Quote
Old 03-23-2011, 09:20 PM   #7
djracer
djracer's Avatar
I don't know how wide these were but the frame wasn't modified.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 03-25-2011, 10:23 AM   #8
limitedstreetoutlaw
limitedstreetoutlaw's Avatar
Well here is what my truck had when i bought it they were 14'' wide wheels with like 9.5 back spacing with 15'' or 15.5'' wide m/t sportsmans on it nothing was cut other than the bed.I woupd think this about as wide as you can go if i remember corectly there was only like an inch or two from wheel/tire to springs.
Brandon
Street Car Mafia
limitedstreetoutlaw is offline   Reply With Quote
Old 03-25-2011, 12:01 PM   #9
limitedstreetoutlaw
And djracer you'r right it's 7.5 back spacing for a 12'' wide wheel thats what i am running on mine now 12'' wide welds with 7.5 back spacing with a 325/50/15 drag radial.
Brandon
Street Car Mafia
Old 03-25-2011, 12:13 PM   #10
1970C10truck
Thanks for the info that was kind of what I was wanting to see.
Old 03-25-2011, 12:30 PM   #11
limitedstreetoutlaw
You'r welcome
Brandon
Street Car Mafia
Old 03-25-2011, 08:31 PM   #12
71chevytruckguy
71chevytruckguy's Avatar
I'm runnin a 28x11.50 on a 10" wheel with 4" backspacing. Took a little bit of hammerin on the inner fenders to make it fit
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 03-26-2011, 12:06 AM   #13
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
Dad is running a 31"x18.5", only mod needed are than widening the wheel tubs and cutting the bed to fit said wheel tubs is finding a narrower spring.
-Automatics win races, 6-speeds impress high school kids
-Save a tree, support your local dragstrip.
-"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui
columbuscarsandcoffee.net and on Facebook
ProStreet68SB is offline   Reply With Quote
Old 03-26-2011, 08:33 AM   #14
ratrod67
ratrod67's Avatar
The widest I could fit with stock tubs was a 15x10 with 5 inch backspacing and a 315/60 Drag radial. Truck was lowered 6 inches in back.
ratrod67 is offline   Reply With Quote
Old 05-09-2011, 12:41 PM   #15
dougminton
dougminton's Avatar
390/45R15 on 12 inch wide rally wheels.
Plenty of suspension clearance but the parking brake cable almost rubs.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 05-09-2011, 09:41 PM   #16
Mack81
What backspace on the teal truck?
'68 C10 SWB
"Purple Nurple"
Mack81 is offline   Reply With Quote
Old 05-10-2011, 07:42 AM   #17
dougminton
dougminton's Avatar
the backspacing is 8". I widened a 15x8 by 4".
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-10-2011, 08:02 AM   #18
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I did the same thing as Doug...I sent out a stock rally and had 4" off back spacing added it was like $50 a wheel...I have put the 31x18x15 M/T's on them with no issues except I had to relocate the E brake cable on the trailing arm.....I can't say if it will clear a stock spring since I'm bagged...but they do clear the outside ( bearly) dumped with a C notch....
I can't figure out how to move pics from my build and since I lost the old puter with the pics I can't repost them..but they're in my build including what I did to tub it
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-11-2011, 09:33 PM   #19
Hart_Rod
Hart_Rod's Avatar
Doug - if you use the parking brake cables from a leaf spring truck, you will have plenty of clearance for your wheels.
I'm running 20 x 12's with a 7" BS (67-70 rear end). The tires are MT 31 x 16's.
Hart_Rod is offline   Reply With Quote
Old 05-12-2011, 12:36 PM   #20
dougminton
dougminton's Avatar
Mine was originally a leaf truck.
What's different on a coil truck?
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-12-2011, 12:41 PM   #21
Hart_Rod
Hart_Rod's Avatar
They are longer, which allows you to route them away from the wheels.
Old 10-10-2011, 08:23 PM   #22
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
I know this thread is a little old but what combo did you wind up goin with? I'm lookin to do about the same on my '69 short fleetside & want to run a 14" wheel.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
