Old 03-26-2011, 04:38 PM   #1
Super73
Super73's Avatar
Solid roller Valvetrain for sale
I was going to run this set up in my 347ci turbo motor for my 73 Camaro. I had a buddy blow his motor up and bugged me for my shortblock. Since it is now gone, I am going to go a slightly different route when I start working on the Camaro again.. So that means I have some solid roller Valve train for sale.
Brand new 1.7 ratio fully adjustable Harlan Sharp Roller Rockers. These are not your average run of the mill rockers from Sharp. The back side is fully ajustable with an allen and lock not so you can set your lash over the valve stem very easily. New they are about $500 Asking $400. They fit stock heads as well as AFR. I had them on my motor to check push rod length.
Comp Cams 7609 7.300" Chrome Alloy push rods. There are also brand new and only put in the motor for mock up. New they are $109 at Summit. Asking $75
Crane Solid Roller lifters. These have been used in another motor. We ran the motor a dozen times on a chassis dyno and made about five or so passes at the track before pulling the cam and lifters out going back to a big hydraulic. They run about $500 new. Asking $350
I also have a cam I was going to run in the turbo setup. I have to look up the exact lobe number from comp but I know it is 236/236@.050 with an intake center of 117 and an exhaust center of 117. If memory serves it is .65x lift with the 1.7 rockers. Next time at the shop I can take a look at it. Custom grinds from comp are $400. I'm asking $300
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
