Jonny
Ultimate underbed tank kit
I have this stuff left from when I was going to build a C10, but it won't work for my C30 because the frame is taller. this should work with any C10 or C20. I have a 40 gallon tank, frame section with the crossmembers, and the fuel door and filler neck from a panel truck. You'll need 37" of frame behind the rear axle to make it work. That's for the crossmembers, the tank is a little smaller.
$200
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 03-26-2011 at 10:41 PM. |
Jonny
Re: Ultimate underbed tank kit
Also wanted to add that this will work in a suburban or panel, too. I measured and was going to use it in mine before I realized the truck was too far gone to bring back.
In trades I need 73-87 cab and chassis dually stuff, side fuel tanks like on a semi, and a 10 ft flat bed.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
I see this is an old thread. Do you still have this? I need the filler neck, door and sheet metal for my 64 fleet. Would you sell me these parts if you still have them?
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
