Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-27-2011, 01:16 PM   #1
Southpaw81
72 C10 conversion from 2wd to 4wd
I've got a 1972 2wd C10 longbed. I want to convert it to a 4wd by swapping my body onto a 4wd frame. There's a complete 68 4wd rolling chassis on ebay that I want to buy but I want to make sure I can put my 72 body on a 68 frame. Are there any differences in dimensions between 67-72 4wd frames that I might run into?
Southpaw81 is offline   Reply With Quote
Old 03-11-2013, 10:51 AM   #2
72on68frame
Re: 72 C10 conversion from 2wd to 4wd
i didnt have any trouble puting my 72 2wd body on my 68 2wd frame but i dont know about 4x4
72on68frame is offline   Reply With Quote
Old 03-11-2013, 04:48 PM   #3
Gene
Gene's Avatar
No troubles at all. Your body will fit, you will need 4wd body mounts though, and some say you must have a high hump trans cover. But mine looked like it would clear with the low hump.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
