03-28-2011, 10:12 PM | #1 |
Hellasick
VIN differs from truck bed
The manual says my truck should be a stepside, not fleetside. Was checking out the manual why doing the curing process for manifold coating and
VIN starts CE140J, manual says 4 is stepside and 34 is fleetside. Nothing unique on the SPID. Did it get changed, or is this common?
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys Last edited by 70C10Toejam; 03-28-2011 at 10:12 PM. |
03-28-2011, 10:28 PM | #2 |
Re: VIN differs from truck bed
C= 2WD
E= V8 1=1/2 ton 4= pickup 0= 1970 J= janesville assy. plant It's your model number that will tell you step or fleet. Last 2 digits.
CHEVY/GMC VIN DECODERS |
03-28-2011, 10:36 PM | #3 |
Hellasick
So why does the manual say 4-Stepside Pickup, 34-Fleetside Pickup on the page that explains the VIN???? GM just that confused???
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
03-28-2011, 10:44 PM | #4 |
model type 04 is cab and stepside bed
model type 34 is cab and fleetside bed I don't know why it's under the vin page, but it's the model number that tells what kind of bed not the vin.
03-28-2011, 10:48 PM | #5 |
Is this a GMC???
03-28-2011, 10:48 PM | #6 |
Hellasick
Looked at the model on the SPID, and the last 2 are "34", Just gotta love it when the manufacturer provides information in multiple places that contradicts itself.
03-28-2011, 10:49 PM | #7 |
Hellasick
Everything says its a Chevy, but now I wouldn't guarantee anything
03-28-2011, 10:51 PM | #8 |
The vin is in chevy format so your good there. Is your model number on the SPID (should be)??
03-28-2011, 10:53 PM | #9 |
Hellasick
Beat ya on that by 2 posts
03-28-2011, 10:54 PM | #10 |
Just saw post 6. 34 is fleetside so your good to go.
03-28-2011, 10:55 PM | #11 |
03-28-2011, 11:05 PM | #12 |
Hellasick
In my work, I just run into this kinda stuff all the time. In a manual for a charger control it says it is set for "X" as factory default and just below the list of those options is says "Y" is the factory default
How can one option have 2 different factory default settings?????
03-28-2011, 11:11 PM | #13 |
At least your truck is right.
03-28-2011, 11:23 PM | #14 |
Hellasick
At least it didn't say it was a COE
03-28-2011, 11:24 PM | #15 | |
The Older Generation
It's just your karma Chad, just your karma... LockDoc
