Old 03-25-2002, 02:22 AM   #1
doughby82
doughby82's Avatar
Post th400 question
is there spacers that go between the torq convertor and the flywheel,i just installed the tranny and there seems to be about 1/4 inch or more space between them after i tighten the bolts
springfield illinois
1982 shovelhead
1967 c10
http://community.webshots.com/scripts/editPhotos.fcgi?action=viewall&albumID=27441460
2003 custom (harley)built from scratch
68 swb
doughby82 is offline   Reply With Quote
Old 03-25-2002, 04:20 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
no spacers that i know of, are your bolts bottoming out on the converter?? you definitely don't want any slack beween the torque converter and the flywheel, I've pulled about 10 of those things and never seen any spacers yet.1/4" is alot of clearance, not much less than when the converter is all the way in the tranny. try shorter bolts and make sure your bell housing is tight to the block.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-25-2002, 10:44 AM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
ive run into this problem too, but on th350, i just uused washers ot take up all the gap between the plate and verter, also there are two styles of verters, one has bolts that thread directly into the verter and then theres the more cvommon nut and bolt style
the bolt only style has big lugs that protrude off the verter and look like they would take up the room of the gap between it and the plate. some applications used them, i have one or two of those dtyle verters here,the 425 79 caddy th400 used it, but the 72 455 th400 car didnt, it used the flat nut and bolt style flange verter, so...
hmm..
-71/C-10(thx teeitup and crews!)350 4+4/CH465(thx 71Chev, GMCPaul, and CPNE)longfleet bed(thnx meathead95)!still building it-
-'84 Z28(Z28) 1G1AP87GXEL100000 with H.O. 305/4bbl/190net/hp(L69) 3.73 rear(GT4/YC4) 700R4(MD8-MXO) & other goodies
-79 G20 pass van, 350/th350/10bolt,
paint is overrated
Randy- Lincoln, IL
r68c30@hotmail.com
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 03-25-2002, 01:43 PM   #4
71GMCstreet
Post
In some cases, you will have about 1/4 in "play" in the converter where is bolts up to the flywheel, unless your flywheel is on backwards. Some of these tranny input shafts/or converter shafts were machined a tick longer/shorter depending on where they came from.
71GMCstreet is offline   Reply With Quote
Old 03-25-2002, 02:06 PM   #5
Fast68Chevy
Post
sound slike bad quality control to me,,.
Old 03-25-2002, 02:41 PM   #6
doughby82
doughby82's Avatar
Post
so i should use a spacer between them,the tranny is tight against the the motor,the verter is thread in,
68 swb
Old 03-25-2002, 07:54 PM   #7
71GMCstreet
Post
Naw....sorry so long for a return post, I've had play in mine since I put it together, no problems, I guess you could space it up for your comfort zone though, should'nt hurt anything either way.
Old 03-26-2002, 12:27 AM   #8
Duallie
Duallie's Avatar
Post
If the engine used to be for a manual transmission, there may still be a pilot bearing in the back of the crankshaft still. That would cause the converter to not fully seat in the crank and give you the gap. Something is wrong.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 03-26-2002, 12:37 AM   #9
69 longhorn
Post
You should have 3/16-1/4" floating clearance between the converter& flex plate.....before its bolted up. The conveter should slide up to sit flush against the flexplate when you bolt it up.....or you have troubles. 69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-26-2002, 02:27 AM   #10
doughby82
doughby82's Avatar
Post
i just removed a th350 from it so it wasnt a stickshift before
1982 shovelhead
1967 c10
68 swb
