Old 03-30-2011, 01:43 AM   #1
tranz am
tranz am's Avatar
"The Northbay G Machine" Tranz Am's 1969 GMC SWB frame graft & build
Ive been working on this truck for a few years now and its come a long way since I Bought it in 2007.
It originally had a 307, 3 on the tree, manual steering, no sway bars, drum brakes, and a lonely leg.
This is what it looked like when i bought it...
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 03-30-2011, 01:53 AM   #2
tranz am
tranz am's Avatar
Re: "The Northbay G Machine" 1969 GMC shorty build
out with the old!
In with the new.
010 350 with an M20
got rid of the but ugly under hood while i was at it too!
My build thread
1969 GMC SWB
Old 03-30-2011, 04:31 AM   #3
tranz am
tranz am's Avatar
Picked up a front suspension, brake set up and a posi at pick-n-pull for a couple hundred.
The front end is off a 75. The rear had new guts including a Eaton posi carrier, score!
couldn't pass up the p31 sway bar
Ordered up some 6 lug slotted and drilled rotors, some 2" drop spindles, 3" dropped springs, a 3/4 sway bar and a flip kit!
My build thread
1969 GMC SWB
Old 03-30-2011, 04:36 AM   #4
tranz am
tranz am's Avatar
Old 03-30-2011, 04:42 AM   #5
tranz am
tranz am's Avatar
Got the flip kit, sway bars, power steering pump and posi unit in!
picked up a trick 12 bolt cover while i was at it.
My build thread
1969 GMC SWB
Old 03-30-2011, 04:45 AM   #6
tranz am
tranz am's Avatar
Grabbed up a pair of seat belts out of an s10 just for safety reasons.
My build thread
1969 GMC SWB
Old 03-30-2011, 04:48 AM   #7
tranz am
tranz am's Avatar
Got the spindles, coils, new ball joints, new bushings, and the brake system now in, its ready to rock!
I like that it sits flush with the firewall.
My build thread
1969 GMC SWB
Old 03-30-2011, 04:50 AM   #8
tranz am
tranz am's Avatar
Another shot of the engine bay at this point.
got the trick flex-a-lite fan and be cool radiator!
Take a look at my booster set up, Its of that 75 square body. I modified the booster and push rod to do this. For the bracket to fit I drilled two new holes in the booster bracket. For the rod i basically just used the rods i had laying around and put a stud inside each end and welded it up.
My build thread
1969 GMC SWB
Old 03-30-2011, 05:01 AM   #9
tranz am
tranz am's Avatar
Broke first gear in my M20 on a back road being stupid
Time for the T5 swap!
I had to make a custom shifter. As you can see its a tight fit.
The shifter is a Hurst short through for a ford T5. Its been modified slightly and half the price.
I had to make a bracket for this conversion being that im using the stock 4 speed cross member and the T5 transmission has a wicked angle on its mounting point because of it.
My build thread
1969 GMC SWB
Old 03-30-2011, 05:12 AM   #10
tranz am
tranz am's Avatar
Installed a mid 80's square body seat. It dropped me down a good 6 inches!
I had to remove the gas tank so i would have room for the seat to be back far enough to clear the shifter. It was time for the relocation!
My build thread
1969 GMC SWB
Old 03-30-2011, 05:23 AM   #11
tranz am
tranz am's Avatar
Had an old summit racing fuel cell laying around and did a little research and found it to be close to the right size for putting it in behind the rear axle.
I also have been thinking about doing a TPI swap later on so I decided to modify the cell at this point and just toss it in the bed.
a cap until Im ready.
My build thread
1969 GMC SWB
Old 03-30-2011, 05:30 AM   #12
tranz am
tranz am's Avatar
Here she sits at this point.
springs have settled in and its even lower than before.
Got some new rubber, 295/50/15's & 265/50/15's.
had 275/60/15's & 245/60/15's on it before.
Now my lower control arms scrape over everything and they are taking a beating.
My build thread
1969 GMC SWB
Old 03-30-2011, 11:05 AM   #13
Beat68CST
Beat68CST's Avatar
Nice lil truck man!
Definitely slick.
Beat68CST is offline   Reply With Quote
Old 03-30-2011, 11:58 AM   #14
tranz am
tranz am's Avatar
Thanks bro
Originally Posted by Beat68CST View Post
Nice lil truck man!
Definitely slick.
My build thread
1969 GMC SWB
Old 03-30-2011, 01:04 PM   #15
tranz am
tranz am's Avatar
Decided to make a hood lock to keep things a little more secure.
Before
Some flat stock
My build thread
1969 GMC SWB
Old 03-30-2011, 01:34 PM   #16
Deenice21
Deenice21's Avatar
nice grill. like the lock too
1971 LWB C10 - 5.3/350
1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet
1964 malibu ss - ls1/4l60
http://67-72chevytrucks.com/vboard/s...d.php?t=382403
Deenice21 is offline   Reply With Quote
Old 03-30-2011, 04:18 PM   #17
tranz am
tranz am's Avatar
thanks! the lock works very well. it definitely adds peace of mind.
My build thread
1969 GMC SWB
Old 03-31-2011, 05:39 PM   #18
RaceAGMC
RaceAGMC's Avatar
Nice ride. I'm used to live in Santa Rosa as well...where do you live?
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 03-31-2011, 07:07 PM   #19
LEEVON
LEEVON's Avatar
Cool build, you CA guys and your rediculous pick-n-pull finds like posi rears. That stuff is long gone around here. I'm glad you got rid of the puke colored brushed on? house paint under the hood! What was that guy thinking?
Shifter is perfect too!
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-31-2011, 08:02 PM   #20
Pyromedic
Pyromedic's Avatar
Thumbs up Re: "The Northbay G Machine" 1969 GMC shorty build
(Greetings from the East Bay! First post, great board with great info so I figured I'd sign-up)
Looks like it's coming along nicely, Tranz. Quick couple of question for you and the other members:
1. How experienced were you with truck work when you started this project? I noticed you are swapping parts and making improvements as you go versus a complete frame-off and build-up, which is what I think I'm looking to do. Just wanted to see if you have been happy with doing it this way.
2. I'm a rookie builder and about all I know about working on cars is how to change my own oil. For a first-timer, would you or other members recommend doing what you are doing or going with a frame-off build-up (both with the assistance of experienced friends, of course)?
Thanks again and truck is looking great!
Pyromedic is offline   Reply With Quote
Old 04-01-2011, 12:15 AM   #21
tranz am
tranz am's Avatar
Santa Rosa Ca?
there are a few Santa rosa's
My build thread
1969 GMC SWB
Old 04-01-2011, 12:19 AM   #22
tranz am
tranz am's Avatar
I have no idea what the previous owner was thinking but the same guy also thought hacking off the drip rails would also be cool. Now i have to cut off some rails and weld them back on (lame).
oh, almost forgot the chicken wire grill inserts
My build thread
1969 GMC SWB
Old 04-01-2011, 01:08 AM   #23
tranz am
tranz am's Avatar
Hey brother. welcome to the site! This is one of the best web sites to find out information. More people are on here than any site Ive been on.
Ive been into cars and trucks since a kid. Ive been well seasoned by the car people in my life before i even touched a wrench. Ive had a lot of experience working on cars and trucks before i got my 69.
I like modifying the crap out of my rides to make them perform way better than they did stock. I also like driving them!
Doing the custom stuff first before getting involved with painting and such will also save you.
Its also fun to make improvements and see the results for each thing as you go.
A full restoration can be a big waist of time and money if you dont have the skills, time, patience and perseverance to finish the job. A lot of people start projects, get overwhelmed and sell them off in pieces for hardly anything.
If your new to this crazy automotive world educate yourself first before tearing into a huge project. trust me
My build thread
1969 GMC SWB
Old 04-01-2011, 01:29 AM   #24
tranz am
tranz am's Avatar
Here is my Custom hidden hitch, fuel cell install, and cross sill modification to accommodate the tank behind the axle.
piece of old shelving
My build thread
1969 GMC SWB
Old 04-01-2011, 01:39 AM   #25
Pyromedic
Pyromedic's Avatar
Hehe, so uh yeah, you're experienced Keep up the great work!
