Old 04-03-2011, 12:25 PM   #1
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Making a trailer from a Pickup
This is a rustfree slightly dented good box on a C20 heavy spring optioned leaf truck so I might as well do it right.
Has anyone made use of the brake system with a surge coupler? The main question is do surge couplers like this have good pressures for the brakes? http://www.tiedown.com/aactuator.html
Also has anyone seen a V mount surge coupler? Most seem to be designed for a 3" single square tube like a boat trailer tongue.
Backup relief solenoid needed?
Just leave the pinion in the rear and let it spin??
PS, this is how you move a nonrunning truck without having to have someone steer it around
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-03-2011, 01:44 PM   #2
mbgmike
Re: Making a trailer from a Pickup
You don't need any solenoid with most surge brake mfg's or anything attached to the truck. if building a trailer out of new stock i would also consider using the new single unit axles that bolt or weld to the side rails. they come complete. they eliminate the axle. Pretty cool. they are made by Timbren. they are avaiible to 3500 lbs per side. from 400 lbs. We sell them but they availble most places
http://www.timbren.com/aeon-rubber-springs.htm
mbgmike is offline   Reply With Quote
Old 04-04-2011, 09:23 AM   #3
Vintage Windmills
Vintage 4x4s
Thanks for the response, I will keep that in mind for future trailers. I plan on using the dana 60 and factory suspension in this trailer.
Still looking for other input...
Old 04-04-2011, 09:55 AM   #4
Grimpala
Grimpala's Avatar
Seems like a waste of a good truck. Find a 73 up to do that with and sell this one.
Grimpala is offline   Reply With Quote
Old 04-04-2011, 10:03 AM   #5
StingRay
StingRay's Avatar
Usually brakes are only required over about 3000 lbs. I'll assume that the trailer will weight 1000 or less. The rear axle and springs on a 3/4 ton was probably only rated for about 2000. How much are you thinking of hauling with it and do you really need brakes?
Also it's pretty easy to weld a piece of square tubing in when you pinch the frame at the front. Bridge the A frame with another piece of tubing and attach the inboard end of the square tongue extension to it. You are adding a T shaped assembly to the middle existing pinched frame rails.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 04-04-2011, 10:55 AM   #6
Vintage Windmills
Vintage 4x4s
Truck had no engine, cab was shot- rusted through on firewall, visor area, kickpanels, rockers, mounts, corners, etc. I parted the truck out. Believe me, I'm all about preserving trucks, but it just wasn't practical with this one. I'd have had more in it than it would be worth.
Good points, I'm thinking of hauling around 2000lbs with it so about 3000lbs total weight. I'd like to stay as safe as possible and no one has ever regretted having brakes. I will use the A frame and T idea you mentioned for the tongue, can get another few inches that way. I always thought most of these trailers had tongues just a little too short.
Old 04-04-2011, 11:26 AM   #7
StingRay
StingRay's Avatar
True you can't be too safe but frankly I've hauled plenty of trailers and never had a problem with the light ones with no brakes. I built a trailer like you want to from a bunch of crap I had for a buddy of mine. They work great. I've used it lots of times behind my own 72 and never felt I needed trailer brakes. FYI I did the tongue as I descibed and it worked great. Like you said you get that extra bit of tongue length.
Canada
Old 04-04-2011, 01:18 PM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I had a long bed trailer a few years ago, loaded it just like my truck and never had brakes on it, didnt need them, my 3/4ton truck had plenty of brakes for both.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-04-2011, 02:08 PM   #9
Vintage Windmills
Vintage 4x4s
So just check/change the diff fluid and call it good? Let the pinion spin?
Old 04-04-2011, 02:48 PM   #10
StingRay
StingRay's Avatar
Hasn't been a problem for the one I built 15 years ago.
Canada
Old 04-04-2011, 03:36 PM   #11
Clyde65
Clyde65's Avatar
I removed the brake stuff, but other than that nothing.
Clyde65
Rebuild of Clyde
support our troops!
Old 06-24-2011, 08:34 PM   #12
Vintage Windmills
Vintage 4x4s
I might do this to a coil spring truck sometime also. I've heard they don't make as good of trailers, is that true?
Old 06-24-2011, 10:04 PM   #13
Hubscrub
Cruzin
Hubscrub's Avatar
i built a trailer with a 86 short bed. I cut a small pie cut in both sides of the frame and bent the frame in toward each other, i bought an A frame coupler from tsc and welded/bolted it to the frame. I used the factory wiring and lights, works great.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-24-2011, 10:11 PM   #14
msgross
msgross's Avatar
I hear they sway a lot and shouldn't be used... Leaf spring is more stable...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-25-2011, 12:07 AM   #15
67_C-30
I have a radical idea!
67_C-30's Avatar
I've got one with coils and helpers, and it does great, but they may sway without helpers (I bought mine this way).
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-25-2011, 12:33 AM   #16
BMERDOC
BMERDOC's Avatar
Everytime I see one of those I get a little choked up. Yet another truck that didn't get to be somebody's hot rod.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 06-25-2011, 09:03 AM   #17
CG
BlahBlahBlah
I bought a 69 Chev C10 with the optional leafs in the rear for the sole purpose of making a trailer with it. I had heard leafs were better for a box made in to a trailer. The rest of the truck is totally shot.
Nother one of my "someday projects"
Old 06-25-2011, 09:17 AM   #18
cdowns
cdowns's Avatar
i dont see a need for brakes on such a small trailer, just another possible problem on the road
you could hookup an altenator to the pinion of the rear and run a refrigerator for longer road trips
Old 06-25-2011, 11:03 AM   #19
m6z
m6z's Avatar
neat idea. I would of never thought of somthing like that.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 06-25-2011, 12:56 PM   #20
Hubscrub
Cruzin
Hubscrub's Avatar
i don't see a need for brakes on such a small trailer, just another possible problem on the road
you could hookup an alternator to the pinion of the rear and run a refrigerator for longer road trips
the possibility's are endless
Proverbs 3:5,6
Old 08-19-2011, 09:17 PM   #21
Vintage Windmills
Vintage 4x4s
Wondering now if I should remove the axles from the Dana 60 so it doesn't have to spin them?
Old 08-20-2011, 09:43 AM   #22
mrein3
mrein3's Avatar
If you're still thinking about surge brakes, look at this setup:
http://www.ufpnet.com/Actuators/tabid/54/Default.aspx
The surge brakes were hanging up on my now 10 year old bass boat. I finally figured out it was the brake rod in the actuator that was rusty and hanging up in the master cylinder. Long story short I orded a whole new A-60 actuator. I couldn't believe how easy it was to install. The surge brakes are over-ridden by the back-up light. Instead of a 4-pin straight trailer connector you use a 5-pin with the 5th pin connected to the back-up lights. When you put your truck in reverse the back-up lights turn on and powers a solenoid on the back of the surge master cylinder which opens up a path for the brake fluid to flow back into the reservoir. Pretty simple really.
I couldn't believe how easy it was to install. The online place I got it from sells a weld-on mount for the A-60. With that in place it is two pins, a brake line connection, then bleed the system with a screwdriver.
10 years after buying the bass boat I read the surge brakes manual. You're supposed to push up a lever when you park your trailer so the brake rod doesn't get corroded and hang up.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-20-2011, 11:04 AM   #23
Vintage Windmills
Vintage 4x4s
^ thanks for the link. Looks like a good product, how much $$ do they run?
Old 08-20-2011, 03:50 PM   #24
mrein3
mrein3's Avatar
I think it was $180 plus shipping for the actuator assembly
'72 Malibu hard top
Center City, MN
Old 08-20-2011, 10:56 PM   #25
sleepertruck72
sleepertruck72's Avatar
I dont think you need trailer brakes if the brakes in your truck are in good working condition. It has worked for me with heavy loads no problem (2-3K#) You may as well invest in a tranny cooler if you dont have one already, or new brake pads for your truck etc. As for the diff, I would drain it out, replace gasket and refill.. Just my 2 cents
Here's a pic of mine.. very similar color to yours
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
