Old 03-23-2003, 06:35 PM   #1
72K10
$300 Steering upgrade
Just swapped out power steering gear box, pitman arm, front and rear draglinks, and both tie rod ends. Steering is now tight and smooth, like straight from the factory. Was an easy swap, particularly if you do the box, pitman arm and draglinks at the same time. But buy the $15 pickle fork and save yourself a lot of time and sweat on the tie rod ends and rear draglink.
RLTW
70C10
72K10
72K10 Cheyenne
72C10 Cheyenne Super
72K10 is offline   Reply With Quote
Old 03-23-2003, 06:53 PM   #2
slogo
slogo's Avatar
what brand of parts did you use? ECE has the kit i went with
slogo is offline   Reply With Quote
Old 03-23-2003, 06:56 PM   #3
1971 Cheyenne
1971 Cheyenne's Avatar
sweet! Also would be curious to find out what brand it is..
'71
Brian Pal
1971 Cheyenne 10 454/th400-Undergoing a full frame off resto.
1972 Chevy short/step 2wd, 350/th350
1983 M1009 CUCV Military K5 Blazer
1981 Dodge 1 ton 4x4 dually flatbed
1971 Cheyenne is offline   Reply With Quote
Old 03-23-2003, 07:05 PM   #4
72K10
I didn't go with a kit. Got the box from Napa for 179 - cheaper than anywhere else for the same rebuild brand - Cardone. Got the Pitman arm from LMC for 39 (only place I could find one). Draglinks came from Advance Auto, TRW brand, for 50 total. Tie rod ends I got from Napa, but can't recall the price since I did those a couple of weeks ago. I did try a Napa draglink, but it was a pain in the butt, spun when torqued. So did their tie rod ends, for that matter. I guess the lesson learned there may be not to grease the joint until after you've installed and torqued it, or it might spin as you try to torque it down. Either that or Napa ball joints are crap, which is very possible.
RLTW
70C10
72K10
72K10 Cheyenne
Old 03-23-2003, 09:11 PM   #5
72shadetree
KEEP ON TRUCKING
72shadetree's Avatar
cool now you wana do mine lol
72 cheyenne 2wd lwb
71 k20 sons
bassett va
72shadetree is offline   Reply With Quote
