04-06-2011, 03:13 AM | #1 |
Any other hood styles besides cowl hoods??
Everyone has cowl hoods... are there any different styles out there? Anyone here built their own? I think it would be cool to do something like a shaker hood. But I have no idea where to start with something like that.
Anyone else done something different and cool?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
04-06-2011, 09:37 AM | #2 |
SWB 4x4 Collector
Re: Any other hood styles besides cowl hoods??
do a search on this link:
http://www.usbody.com/
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
04-06-2011, 10:54 AM | #3 |
That is a cool site.... they only have cowl hoods for the 67-68. I like the ram air for the 69-72. It look pretty awesome.
04-06-2011, 05:23 PM | #4 |
If its for the gmc in your sig a 676-68 stock one may be a mice touch there was also a thread on flat hoods a while back
70 SWB STEPSIDE 70 BLAZER 09 challenger |
04-06-2011, 05:30 PM | #5 |
I'm looking for a 67-68 hood but I'd like to do something other than just a plan hood or cowl hood. Everyone has one or the other.
04-06-2011, 05:39 PM | #6 |
I want to put a 79 t/a shaker on mine..
04-06-2011, 06:16 PM | #7 |
04-06-2011, 10:31 PM | #8 |
That would be pretty awesome too. Anything to just be different from everyone else.
04-06-2011, 11:13 PM | #9 |
I want the T/A shaker also; lets see if anyone here has some insight...
71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
04-07-2011, 12:10 AM | #10 |
wouldny you just need to trace the hole on a shaker hood then cut it in a flat hood and stick the shaker air cleaner thingy on there? i mean i would clean the cuts and every thing up and it make it look pretty. i want to make a 70 chevelle functional cowl hood for my truck
68 C10 LWB 2/4 drop 406/th400/3.73posi 04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD |
04-09-2011, 09:06 AM | #11 | |
04-09-2011, 01:21 PM | #12 |
Pick up a old hood and install on your truck, measure from the firewall to the lower edge of windshield and from the firewall to the center of the carb. close the hood and add both measurements and drill a small hole on the hood. this should put you close to the center of the carb. i would check with a rod with a drop of paint on the end, dropped straight down the hole. once you find the center of the carb on the hood, you can trace & cut out the area from your shaker. close the hood and measure the space between the carb and the hood for any spacers that you need to raise the shaker the the desired height. check the alignment and if good cut out your good hood and install.
04-09-2011, 03:22 PM | #13 | |
04-09-2011, 10:39 PM | #14 |
04-10-2011, 12:29 AM | #15 |
i'ved used Unlimited Products for front clips and hoods before. http://up22.com. I'm sure they have alot of the same stuff as US body though, but I've never used them. Like posted above, grab a spare hood, a scoop or insert, and go to town on it. With a little hard work you'll have a complete one-off. The best part is when everyone asks you where you bought it, you can stand proud saying its built not bought! Oh no...now I'm getting ideas for mine.
04-10-2011, 01:10 AM | #16 |
My Carbon Footprint
Chevy nailed it with the 67-68 hood and front end!
04-10-2011, 01:36 AM | #17 |
there was a guy back in 05 or 06 doing a 70-72 oldsmobile cutless ram air hood that was turning out nice. ( hard to imagine huh?) I don't think he ever did finish it but might be worth a search.
04-10-2011, 10:10 AM | #18 |
the boat guy
you could put some of those lund stick on scoops. You just stick them on, no body work, hell you don't een have to paint them to match your truck. Well it's the popular thing to do around here anyways.
personally I'm a stock hood kind of guy.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
04-10-2011, 10:46 AM | #19 |
I installed a pair of 68-69 Camaro Louvers on my '65. We all know these were not functional on the Camaros but I have designed a "cowl induction" style air cleaner arrangement to pull air throught the louvers. I have purchased some of the components, but still need to fabricate some additional parts and find the time to finish the installation. A lot of other things to do on my truck though before then.
04-10-2011, 11:47 AM | #20 |
04-10-2011, 07:45 PM | #21 |
Lakeroadster; hi, i wonder if your vents would act like a venturi and pull air out of the carb. unlike a cowl scoop which uses the low pressure zone at the bottom of the windshield to move air into the carbs. i would tie a small ribbon on your vents and drive it around to check the air flow at various speeds.
09-09-2011, 11:17 PM | #22 |
lakeroadster, any more work done on this?
09-10-2011, 06:55 AM | #23 |
1969 Custom 30 wrecker
I welded in a pair of 68/69 Chevelle SS scoops into my hood last fall. (had the hood in my garage collecting dust for eons that I bought for $25 dollars)
I've never seen it done with this year before so I guess it's a one of a kind for now. I also changed to 69 Chevelle SS marker lights. I guess my C10 is now a C10SS? P.S. I think the 70-72 Chevelle SS domed hood scoop or cowl induction would be awesome but I didn't have any of those "lying around." lol
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
09-10-2011, 07:03 AM | #24 |
Six in a row makes it go...
Any pics with the grilles in? Looks good.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
09-10-2011, 07:11 AM | #25 |
Here's one but the left side still has to be tightened down in this pic. Also a pic of these in primer that shows more detail.
