Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 04-11-2011, 12:14 PM   #1
tech@scottshotrods
Scott's coil over cross member with splined sway bar
I know alot of you guys have been asking about a coil over cross member, here is our coil over version which seems to be our most popular, we have been selling these for a little over a year now and seem to be out selling the super slam close to 3-1.... The picture shows it with the optional splined sway bar, we build these to order, and can build them to your spec.
tech@scottshotrods is offline
Old 04-12-2011, 04:13 AM   #2
darkhorse970
darkhorse970's Avatar
Re: Scott's coil over cross member with splined sway bar
Can you tell me how much drop is possible with this front end? How adjustable is the ride height? Is there any difference in ground clearance (clearance to a-arms and other suspension or steering components) from stock suspension w/ 4" drop?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline
Old 04-12-2011, 07:08 PM   #3
Scottshotrods
With our coil-over set up with our stock spindals you will have a 4 1/4 drop
from stock height.
If you run our drop spindals you will have a 6 1/4 drop from stock height.
For you steering hook up you will need to run 3 u-joints to hook up to your
steering column and you can run your stock column if you want to.
Our lower a-arm pivot is above the the bottom of the crossmember and the lowest part of our front bolt in ifs is the bottom of the crossmember which has good ground clearence to the ground so nothing will drag.
On our coil-over front you have 1 1/2 adj on height.
Justin
Scottshotrods is offline
Closed Thread
