Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 11-26-2003, 02:08 AM   #1
71swb4x4
71swb4x4's Avatar
Unhappy Can I add factory AC?? Help!!
Hi everyone. New here. Does anyone know if I can add AC to truck? I realize it will cost money - and lots of time But will the factory AC equpiment bolt into my non-AC cab? I have a 71 1/2 ton, 4x4, SWB - and I love it!!!
71swb4x4 is offline
Old 11-26-2003, 02:15 AM   #2
dinnut
dinnut's Avatar
youll have to do some cutting to the dash if you want it in the little factory balls, but, yes it should i beleive. you could probably even go with an aftermarket unit like old air, or a vintage air unit. and get r134 instead of the r12. if i were you id just get a vintage air or old air. some of the vendors on here probably sell the complete kit. got any pics of your truck. and welcome to the board
70 longbed
496/th400/Ford 9"
dinnut is offline
Old 11-26-2003, 02:16 AM   #3
71swb4x4
71swb4x4's Avatar
Thnks
I have a factory air dash that I am going to weld in, just wasn't sure if the ac parts would bolt into the firewall. I will get pics up soon.
71swb4x4 is offline
Old 11-26-2003, 02:18 AM   #4
shadetree
shadetree's Avatar
It definately CAN be done, as I have done it. There are 3 major hurdles. One is: getting all the air conditioning stuff, two: to be 100% "factory" you will need to cut holes in the ends of the dash, to house the outlets, and third: air conditioned cabs have an extra hole (you would have to carefully cut this hole, too) in the firewall, behind the heather/AC housing. Cutting the holes in the dash is the hardest part IMHO, as the holes are angled on the slope of the dash area next to the instrument cluster/glovebox.
If you want to try it, I might be persuaded to part with my factory air stuff, E-mail me, if interested. steve
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline
Old 11-26-2003, 11:11 AM   #5
Gee_Emm
The hole for the heater box on the firewall will have to be modified. You will have to weld in a sheet of metal in the exsisting hole and cut a new one out. Cutting the vents into the dash is way easier then replacing the whole dash board IMO
Gee_Emm is offline
Old 11-26-2003, 11:19 AM   #6
Hutch
Hutch's Avatar
This might help:
Here is a link from a previous thread about a custom install:
http://67-72chevytrucks.com/vboard/showthread.php3?s=&threadid=75974&highlight=a%2Fc+firewall
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline
Old 11-26-2003, 12:11 PM   #7
VTKidder
Why is that? I can see that the hole above the radio would be a snap, but the outer holes appear to be a pain in the ace. I assume there is some slop that can go along with the outer holes as the vent housings are like 3/8-1/2" thick on each side, and will cover sloppy cutting. How'd you do it? Get the vents and what not, then have CPNE come with Boz-All and just hack until everything fit? I'm going to add an AC dash for a future AC conversion, and want to make sure I'm not opening a big ol' can of worms removing and adding a new dash. Thanks Gee....
-adam
VTKidder is offline
Old 11-26-2003, 06:49 PM   #8
mrein3
mrein3's Avatar
The firewall sheet metal is easier to modify than you think.
Refer to the picture Hutch posted.
The non-existant yellow hole has a factory dimple to line it up for the heater core. Use it to center your hole punch. The red and yellow holes in the picture that look like they don't line up really do.
Take a piece of paper to your non-ac firewall and make a trace of the heater hole and the two holes for the heater core. The heater core holes become your reference points. pic 1
Then take your future AC evaporator holder assembly and make a trace of that, including the two holes for the heater core. pic 2
Then take the two tracings and line them up using the heater core holes to line them up.
Cut out the piece of paper you need to create the metal you need to weld in. It sort of looks like a "J". pic 3
Finally hold your metal J in place and make any final trimming adjustments. pic 4
Then weld in the J and cut out the hole using your template from pic 2 for where to cut.
Pictures to follow...
pic 1 -
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline
Old 11-26-2003, 06:51 PM   #9
mrein3
mrein3's Avatar
pic 2
'72 Malibu hard top
Center City, MN
mrein3 is offline
Old 11-26-2003, 06:52 PM   #10
mrein3
mrein3's Avatar
pic 3
'72 Malibu hard top
Center City, MN
mrein3 is offline
Old 11-26-2003, 06:53 PM   #11
mrein3
mrein3's Avatar
pic 4
'72 Malibu hard top
Center City, MN
mrein3 is offline
Old 11-26-2003, 09:23 PM   #12
Gee_Emm
The whole dash board doesnt come out as easy as it looks. There are spot welds on each side that are very difficult to get out.
Cutting the side vents is just as easy as the middle one. Ideally you need to have access to a AC cab. Take a sheet of white paper, cover up the vent hole with the paper wrapping around the bottom of the dash board a bit. Using your "garage hands" (dirty hands) rub the outline of the vent through the paper. Without shifting the paper at all rub the detail of some of the holes that are underneath the dash, one of the holes is for the e-brake assembly to attach to I think. Cut out the shape of the vent hole that is marked on the paper. Using the underdash reference holes that you made line up the paper on the dash you want to cut the hole in. Mark and cut. DO NOT use a sawzall, I would recommend roughing it with a cutting wheel and finishing it up with a die grinder.
Gee_Emm is offline
Old 11-26-2003, 09:53 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used a plasma cutter on mine very easy and the guy only charged me 15 buck's to cut the vent hole's then I dressed the hole's up and installed the vent's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 01-01-2004, 10:12 PM   #14
ddsmith
Glowing since 1978
ddsmith's Avatar
Shawn,
Since your starting from zero. I would strongly recommend using the factory evap, TXV and POA valve readjusted to the proper setting for R-134A. I did the aftermarket route and I regret the choice. The evap on the factory truck is bigger than the aftermarket units. It can transfer more BTU's meaning cooler cab temps. It also keeps the factory defrost and heater which is a plus. I currently have no lower heater vent outlet because of the aftermarket setup. As for compressor and condenser I would probably use aftermarket units. The benefit of the POA setup is that the compressor continues running and the POA modulates to maintain the pressure and temp at the evap just above freezing when in the A/C mode. This provides the coldest air possible with a large air flow.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline
Closed Thread
