Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-15-2011, 09:51 PM   #1
86 silverado short
how many amps
hello, I`m wanting to know how many amps i will need. I will be using
1 - 10" woofer
2 - 6x9
2 - 3.5" for dash any help or ideas please
86 silverado short is offline   Reply With Quote
Old 04-16-2011, 12:07 AM   #2
trz1000
Re: how many amps
You need one for sure for the sub. Ideally you'd have a four channel to run the 6x9's and 3.5's and a mono amp for the sub. Assuming you use decent amps, it'll sound better that way than by using the head unit to run main speakers but if you're doing it on the cheap, all you need is one amp to run the sub.
In my Jimmy I used a Clarion PDX5, it's a 5 channel digital amp. Being a digital amp it doesn't require huge heat sinks so it's smaller and can be hidden in an area with less air flow than a solid state amp. It runs a 10" sub and two sets of 6x9's very well. However, it is pretty spendy though not too bad when comparing to buying a good 4 channel and a mono, not to mention the space savings.
I run my Jimmy topless all the time and the stereo sounds great, for a drop top. With the top on it's awesome as the bass response is greatly enhanced. It hits pretty good topless and almost hurts with the top on.
Some guys don't like 5 channel amps, they say that you can get some cross talking. I've never had any issues but I'm also not a pro audio installer.
Anyway you go, you don't have to spend a fortune to get a good sound. For great sound, be prepared to drop some bennies.
trz1000 is offline   Reply With Quote
Old 04-16-2011, 01:34 AM   #3
von guido
von guido's Avatar
Re: how many amps
in my truck I have a 350 watt amp powering a 10 inch audiobahn sub with an alpine HU powering the stock speakers..sounds pretty good and rap hits HARD.
officer,we weren't racing.. he was merely pacing me.
von guido is offline   Reply With Quote
Old 04-16-2011, 09:51 PM   #4
Bad70sbchevy
Bad70sbchevy's Avatar
Re: how many amps
I'd say two, one for the speakers and one for the subs. I'm running an ancient Jensen 208W amp powering two alpine type-Rs and a 300W Dual powering two 12" Pioneers behind the seat. Haven't really got to run the subs under full power yet, need to strap down the box better before I can do that .
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 04-17-2011, 01:14 AM   #5
KC_Goose
Re: how many amps
One amp for the sub and another to power the 6x9's and dash speakers...im running 2 12" kicker L7's with 2 kicker 1200.1 class d amps
KC_Goose is offline   Reply With Quote
Old 04-17-2011, 11:06 AM   #6
86 silverado short
Re: how many amps
Thanks for all the great advise. anyone else. Well it sounds like i need to save and get two amps.
Old 04-17-2011, 02:24 PM   #7
Jparks
Jparks's Avatar
Re: how many amps
You can find a few amps out there that will run all your speakers. It'll be a 5 channel, with 4 slightly lower powered channels designated for your highs and a higher powered mono for your sub. Check out crutchfield, they have a good selection.
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 04-19-2011, 02:24 AM   #8
kp110477
kp110477's Avatar
Re: how many amps
I'm relatively new to this site, but I have been doing a LOT of research lately on how to build up my '89 Chevy Suburban... Anyway, the point is, I ran across an ebay store that sells mid-range/high-end stuff for about half the price as bestbuy, crutchfield, etc..... check them out. I haven't bought anything from them yet as I'm still in the research stage of my entire build up. Best of luck. http://stores.ebay.com/discountcentralonline
kp110477 is offline   Reply With Quote
Old 04-19-2011, 01:04 PM   #9
stich626
Re: how many amps
1 - 10" woofer
2 - 6x9
I'd run one good bridge able 4 channel amp
why..
well unless you have a very high end head unit it has amps in them..
and your dash speakers are not gonna take more power than what most headunits are gonna give you..
then run the 4 channel amp 2 channels to the 6 by 9's hooked from the head units rear rca outputs..
then bridge the other two channels to get a nice high power to run your 10"
most good amps that can run this way will have a highpass and lowpass filter
so the bridged channels are not working to power anything but low end bass..
and not wasting power on mid's and highs
I've had great luck with rockford fosgate and jl audio
if you where running a pair of 12's I'd say run a 2nd amp for the subs
but with one 10"
one amp will be better as you'll buy a higher quality amp instead of two lessers for the same money..
and be happier, also the wiring will be easier and cleaner.
running the dash speaker from a amp is fruitless as the 3.5" speakers can't use the power and you'll be turning the power down either through the use of the amps gain or the head units fader..
good luck
stich626 is offline   Reply With Quote
Old 04-22-2011, 05:10 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
Re: how many amps
I agree with both Jsparks and stich626...
I'd price out the difference between a bridgable 4 channel and a 5 channel (both of very good quality) and go with the cheaper one...
1970 2wd Blazer
tubbedII is offline   Reply With Quote
