04-16-2011, 03:01 PM | #1 |
70+ ( Old Skool Club )
Suburban Spid Label Help
I posted this on the Burb board and only had one response so I'm hoping to get more responses here. On the attached Spid does anyone know what the " Superlift Rear Shock " option is, I'm thinking air shocks? Also what is in a "Spring Promotional Package" and it was suggested by 1956Cameo it may be the highlander package. Is the Turbohyramatic transmission a 350 or 400? Lastly it says "Air Conditioning-OV" and the Burb has rear A/C but its not mentionedon the Spid and I'm thinking the OV might mean rear overhead A/C?
I'm getting close to making adeal on this Burb but the seller is being tough with the price.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-16-2011, 03:17 PM | #2 |
Garage wrench
Re: Suburban Spid Label Help
Ok, here is what I have...
the Air Conditioning option is in fact for rear a/c, hence the "C69" part of the option code, indicating rear aux a/c Next the spring or special promotion could very well be a highlander package option. The rpo code is just an trim option code. Lastly, the superlift rear shock is in fact air shocks. GM calls the option code G66 a Manual Air Level Control system, via air shocks. Seems like a decent 'burb, hope the info I provided helps.....
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
04-16-2011, 04:14 PM | #3 |
Roadtrip!
The M49 trans code was used for both 400 and 350 trans. Since that is a 72 with a 350, probably a 350 trans.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-17-2011, 03:07 PM | #4 | |
04-17-2011, 04:02 PM | #5 |
Roadtrip!
Where are you seeing a spring package? I see the promo package...
I will still say the trans is a 350 if original and also thought it was odd to not have a gauge package. It could be correct, just odd for that setup. Looks like a nice rig.
04-18-2011, 02:11 PM | #6 |
Yea, your right I sI just thought of Spring Promotional Package because that is what they called them when I was in the car business in the 80's and 90's. If it had the tach dash it would be awesome but again I'm not going to ask the seller.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 04-18-2011 at 02:12 PM. |
