04-20-2011, 08:54 PM | #1 |
4wd front drive shaft - need help
1972 K5 Blazer, 350, 4 speed, NP205 TC. Started hearing a steady "bump" sound at slow speeds when in 4wd with hubs engaged. Seems like it is the front drive shaft because, although the two universals are tight, there is play at the joint in the driveshaft and it gives a slight clunk when I move the shaft up/down at the joint - the two parts are not mated firmly.
Never before noticed that the shaft is two-piece and, of course, never seen inside the joint. The shop manual does not show or describe the drive shaft. So, before I start taking things apart, need some wisdom from you experienced guys. Is that joint splined, and how is the connection made tight and without play? Is there a bearing in there, or? Does anybody have a pic of the inside setup or a parts blow-up showing what is going on inside there? All help will be appreciated. Thanks for reading.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp Last edited by CCCC; 04-23-2011 at 10:30 AM. |
04-21-2011, 03:02 AM | #2 |
Re: 4wd front drive shaft - need help
Its a cv joint and its two u joints and then a "thing" in the middle of them, Can't really remember what its called, Its been a while since I've taken one apart. But I believe the "thing" is the part that commonly wears out. Should be able to have a driveline shop rebuild it for not very much. I'm sure somebody will correct me if I'm wrong or give you the correct terminoligy.
04-21-2011, 06:32 AM | #3 |
Yes, it is a spline and yours is worn out. You need to take the shaft to driveline shop and have a new slip joint welded in. It is very common for that slip joint to wear out over time. Should be $150 - $200 at the most.
Tim |
04-21-2011, 11:20 AM | #4 | |
20' Daredevil (Ret)
04-21-2011, 12:48 PM | #5 |
The picture that Stocker posted is what I was talkin about but I forgot about the slip yoke. Oops
04-21-2011, 04:31 PM | #6 |
Great. csb#356, Blazer1970 and Stocker - thanks for the info. I am in good shape and will remove and fix - except that the closest drive line shop is over 200 miles from home. Maybe I can find a good on on the Forum.
It seems simple enough once encountered, and have to look at the other 72 Blazer to see what shape it is in. Actually, this part would seem to be a really weak spot in these Blazers because, although this truck has over 100k miles, not very many of them are actually in 4wd and the remainder of the stuff from TC and forward is strong and tight. Now that I think about it, I have to wonder why GM did that spline joint - seems like the earlier 4wd had a solid shaft. Anybody? Thanks again.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
04-21-2011, 08:37 PM | #7 |
It has to be splined for the shaft to get longer and shorter when the suspension cycles.
04-23-2011, 10:28 AM | #8 |
Anyone know any sources on this forum (or elsewhere online if necessary) to reasonably purchase a good used, or new/rebuilt splined front drive shaft for 72 Blazer?
04-23-2011, 10:38 AM | #9 |
I'm not super familiar with the pre '73 stuff, what are the differences with the front driveline at the year/body change? Copied from Craigslist~~ "73 4x4 blaxer front and rear drive shaft for sale" - (albuquerque )
04-24-2011, 04:29 PM | #10 |
Thanks Mkcustums - I am following up on that ad. Does anyone here know off the top of your head if the stock drive shafts on a 73 Blazer are identical to the 72? Thanks for any info.
04-24-2011, 05:05 PM | #11 |
If the one out of the 73 is from a 205 t case then it will work. 203 and 205 transfercases have different length driveshafts. You also just have to make sure that your driveshaft and the one your getting have the same yokes. Some 70s trucks have square yokes on the transfercase. And its also hard to be sure that this other shaft doesn't have the same issue as yours because I have seen a lot with that problem.
04-24-2011, 09:13 PM | #12 |
Yeah, it's kind of a gamble really. Like he said, it might be as bad, possibly even worse.
04-25-2011, 12:24 PM | #13 |
I just had my front drive shaft completely rebuilt.
I think it was around $350 for everything. Slip Yoke, CV Joint and U-joints. Once removed you should be able to feel/see what is wore out. If the center ball of the CV Joint is good and the Yoke is good you should be able to replace the U-joints yourself.
'72 K-10 SWB Stepside 4" Lift |
04-25-2011, 07:09 PM | #14 |
With the shaft still on the truck, both universal joints seem very tight - no play at all in the joint connections at either end, so maybe will just need to clean and re-pack them with grease while apart.
Thanks for the info DavTay. Never have had this assembly apart, so have never noticed a "CV Joint". The front of the drive shaft connects directly to the front diff, so when you mention "CV Joint" do you mean the joint at the front of the transfer case where the back end of the drive shaft U joint connects? If that is a CV Joint, is it ordinarily a bad wear spot? I am checking out the shaft that is for sale - hoping that it fits properly and is not worn at the splined joint. Thanks for all info.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp Last edited by CCCC; 04-25-2011 at 07:27 PM. |
04-25-2011, 07:26 PM | #15 |
Easiest thing would be if you could snap a couple pics of what you have. (if you can)
04-25-2011, 09:57 PM | #16 | |
I think the rear CV joint would be an area of wear because it very difficult to grease. It has three grease fittings, one for each u-joint and one for the middle ball. My new ones have the flush grease fittings. Sounds like the middle ball is wore. This would allow you to push up on the shaft and feel movement if the u-joints feel good. Removing it will really tell you what is wore. When i removed mine the u-joints seemed decent but the middle ball in the CV joint had a whole lot of slope. Removing the drive shaft is relatively easy. The hardest part is removing the long bolts at the t-case. You can only turn the bolts a very little at a time. I found laying on back, propping up my head on a soccer ball and using a short wrench I was able to remove them. Find the position which works and then just rotate the shaft to loosen each bolt. I found it easier to remove the bolts when they were located on the top. If you do a search you will find other posts on front drive shaft removal.
04-27-2011, 03:43 PM | #17 |
Thanks for the notes guys. I am getting ready to remove the shaft today or tomorrow. The splined joint DEFINITELY is worn and has noticebale play. I now understand about the location of the CV joint/ball and will take a good look. I have kept this truck very well lubricated and am hoping that there is no big wear at the CV ball. Right now there is NO play or movement at that universal and CV joint no matter how i position the shaft. Hoping for just a splined joint repair, but am also looking for a good/tight shaft and CV joint to buy here from someone. Know anyone?
Here are a couple of pics of the situation. #1 Splined joint. #2 Front joint #3 Rear CV to transfer case
04-27-2011, 06:57 PM | #18 |
20' Daredevil (Ret)
I may be wrong, but to me, those pics don't seem to show evidence of a lot of lubrication. Maybe you keep your stuff cleaner than I do...
In the last pic, there appears to be a reddish tint around the u-joint closest to the camera. That might indicate rust from the needle bearings.
04-27-2011, 09:52 PM | #19 | |
Once removed I would check everything out. Check the CV joint for free play at the pivot ball. Definitely replace the u-joints, bad or not, there cheap. If you replace the u-joints yourself mark the joints so you install them back in the same position. When I got my front shaft replace the CV joint had flush grease fittings. If the slip yoke is bad a drive shaft shop will need to cut the old yoke off and weld in a new one. Grease everything up once installed. Keep us posted on the outcome.
04-28-2011, 01:06 AM | #20 |
Took the shaft down today. The universal joints all were tight before disassembly, the needle bearings greasy and in good shape - but nice and clean inside each cup - that is, no dirt and no rust. It was a bear to get the rearmost U joint apart - the bearing cups were in there tight and I did damage two of those slightly flexible/bendable rings into which the bearing cups insert. Am wondering if a guy can buy those separately if I decide to re-use those assemblies.
On the other hand, I would prefer the U joints that have normal grease fittings (already installed those in the rear shaft) and may just buy new ones with that feature. Cannot yet tell if the CV joint is good. There was grease in there and the needle bearings are good, but there is a bit of play between the ball and socket. Is that normal? The ball seems to sit down into a curved recess at the back of the socket - but then there is some play between the ball and the open front of the socket. Is there some sort of rubber or plastic liner between the ball and the socket at the front? I have to clean that up and take a closer look. Now that it is down, probably should go ahead and replace the CV joint anyway. Can a guy buy these components separately, do they come in a kit, or ?? Did not have time today to open the splined shaft area, but once off the truck it seemed to have very little play - less that it had when sitting horizontally and attached at both ends. It had a very visible wiggle then. Thanks for any observations and info. More later.
04-28-2011, 08:44 AM | #21 | |
My new CV joint had no play in the ball, there is no plastic in there, just metal to metal. As for the grease fittings, I believe you can use standard ones on the CV-U-joints but I believe the one for the ball and socket needs to be flush due to clearance issues. The CV-Joint has the be cut off and welded. So, based upon your findings I think the clunking sound must have just been due to the wear in the ball and socket in the CV-joint.
04-28-2011, 01:47 PM | #22 |
CCCC Here is a page that might answer some questions and get you a little more familiar with what you are dealing with. I hope it helps!
http://www.pirate4x4.com/tech/billavista/PR-shaft/ |
04-29-2011, 06:58 PM | #23 |
Thanks Mkcustums - excellent site with nice illustrations and gives the correct terminology. I hope I don't have to use those terms too often in the future, but there are four old 4wd Chevs here..
Having taken the double cardan apart I understand how it works and what is needed. Now I have to decide between pre-lubed/sealed or periodic lubed joints and where to get the best quality stuff for a price. After reading everything, I want to get Spicer parts, and this site may be the place. Thanks again.
04-29-2011, 07:15 PM | #24 |
DavTay, I think that you are correct about the source of the problem now that I have inspected the ball portion of the double cardan joint. The splined slip joint looks good upon inspection - no significnat wear or play, and the side to side wiggle seems very minor now that the shaft is off the vehicle.
Now am looking for a good source and decent price to buy the Spicer brand ball/socket portion of the double cardan CV assembly and also three new U joints. Although the three current U joints are tight and clean, I would just as soon replace them while I have this shaft apart - then will never have to do it again in my lifetime. Next time will be a grand son's task.
05-02-2011, 04:09 PM | #25 |
Jamie Hyneman is my twin
I bought a whole front shaft off of ebay from this guy. http://myworld.ebay.com/cjtatton
I have been very happy with it. I think I payed $250. It came with 7-9 inches of slip spline.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
