Old 04-24-2011, 12:04 PM   #1
Chris Guthro
Mid 13's?
Just a curious question, my freind took his B18 civic to the track and ran 14 seconds. Im wondering what it would take to move a Long Box 2wd into the mid 13's. If you guys have combos that do that, please let me know what you did.
Chris Guthro is offline   Reply With Quote
Old 04-24-2011, 12:12 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Mid 13's?
DEEP pockets !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-24-2011, 12:14 PM   #3
manimal
manimal's Avatar
Re: Mid 13's?
I have a friend that has a '58 shortbed(all steel) w/ a 468,9.0:1,comp cams 280,air gap and a 750 barry grant carb,hooker headers,stock 781 heads,stock th400,peg leg rear axle w/4.10's and runs 13.71 here in Fontana.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 04-24-2011, 12:15 PM   #4
Chris Guthro
Re: Mid 13's?
Yea I kind of understood that fact about, but it would be spread out between now and next summer so it shouldnt be bad at all.
Old 04-24-2011, 12:32 PM   #5
Chris Guthro
Re: Mid 13's?
Yea I kind of thought it would atleast take a big block, more than likely a 454, good automatic with a shift kit. and the right rearend
Old 04-24-2011, 12:32 PM   #6
jimbonice
jimbonice's Avatar
Re: Mid 13's?
Big block or small block?
jimbonice is offline   Reply With Quote
Old 04-24-2011, 01:25 PM   #7
Chris Guthro
Re: Mid 13's?
going to be big block if thats what it will take. but would go small block if its a option
Old 04-24-2011, 01:31 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Mid 13's?
Do an LSx 6.0 conversion....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-24-2011, 01:32 PM   #9
texasfunk
texasfunk's Avatar
Re: Mid 13's?
Small block or big block can both get you where you want to go. But it depends on what drivability your looking for..and how much you want to spend. Either way..won't be cheap
texasfunk is offline   Reply With Quote
Old 04-24-2011, 02:14 PM   #10
Chris Guthro
Re: Mid 13's?
well i have access to a couple 350 blocks..how much building of it would be involved to pump out about 400 horses without doing 383?
Old 04-24-2011, 02:14 PM   #11
jrcaprai
Re: Mid 13's?
my truck ran low 13's with a 383... flat top pistons, older Dart Pro 1 200 cc 64 cc Chambers, Comp EX284 Hydraulic Flat tappet cam, RPM air-Gap, Demon 750 this was dyno-ed at 430 HP
Turbo 350 with a 3000 RPM Converter and 3.73 Gears and Drag Radials
jrcaprai is offline   Reply With Quote
Old 04-24-2011, 02:19 PM   #12
jrcaprai
Re: Mid 13's?
you could do it with a set of AFR or Profiler 195 cc Heads
Comp XE274 or XE 284 or a similar Lunati Voodoo Cam or Roller Cam
Flat top pistons, Air gap or Vic Jr intake , 750 CFM Carb...
you'll need a 2500 -3000 RPM Converter 3.73 or higher gears
Good ignition system
Don't Scrimp on heads... Most of your horsepower comes from the heads.
Why not a 383 ??? it is just as cheap to do a 383 as a 350
Old 04-24-2011, 02:19 PM   #13
Chris Guthro
Re: Mid 13's?
Thanks Jr! What about a 400 block instead of a 383? 400 with vortecs, ported and polished, planed. RPM air gap, and a 750 carb?
Old 04-24-2011, 02:26 PM   #14
jrcaprai
Re: Mid 13's?
Yep, I have a 400 in mine now.... you'll spend a lot of $$$ getting those Vortecs up to snuff, and you still would not have the performance of a Profiler or AFR .. you'd be better off to start with Profiler 195cc Check out this link
I bought a set of the 210 cc for 1300.00
http://www.speierracingheads.com/profilerecono.htm
Old 04-24-2011, 02:29 PM   #15
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Mid 13's?
just go with the newer technology small block...and LSx. A 6.0 with a few bolt ons would get you there. You don't have to go EFI either....
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-24-2011, 02:31 PM   #16
Chris Guthro
Re: Mid 13's?
they look like a real nice head, and probabley bang for the buck. But what kind of porting can be done to vortecs? because i have a set now sitting on a 96 vortec 350 that i may considering redoing.
Bore it .060 over
flat top pistons
headers
RPM air gap intake
Edelbrock 750
Carb spacer
Lunati Cam (not sure yet) still want to daily drive it
B&M shift kit Th350 or Th400?
Old 04-24-2011, 02:34 PM   #17
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Mid 13's?
a stout small block, with built trans with a stall converter, low gears sticky tires, traction bars and
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-24-2011, 03:11 PM   #18
jrcaprai
Re: Mid 13's?
Porting is not cheap! here are some prices for just porting, and that is not including Hardware... Rocker studs, Valves, retainers, locks, seals, etc...
it makes the 1300.00 look pretty good
Cylinder Head Porting from Dr j's and speiers racing heads
Includes the following
Fully radius short turns on the intake and exhaust
streamlined guide bosses on intake and exhaust
maximized push rod pinch opening
bowls blended to
gasket matched
Before and After flow testing
At Dr J's Performance we do not believe on individual stages of porting, because it does not benefit the costumer. Our goal is to provide the customer with most amount of performance per dollar spent. Every head that leaves Dr J's performance is ported to its maximum potential.
Aluminim Heads starting at $ 700.00
Cast Iron Heads Staring at $ 825.00
STANDARD PORTING* This includes valve job and all the critical areas sized to your
combo, throat, bowl porting, and chamber finished. Exhaust port cleaned up. The areas
worked are then blended. This is NOT a full hard rolled port. I'll give you the flow sheet
for future cam choices and combos. 18-20 hours of grinding and flow bench work. Prices
start at $1000 for SBC
FULL PORTING* All out porting and velocity profiles. This includes multi angle
valve job, hand blended. All of the above with a fully hard rolled intake and exhaust
port and chamber. Exhaust port exit is sized. Exhaust port is FULLY polished.
Contouring the guides. Port mapping to achieve proper velocity. Chamber is sized to
bore. Attention to detail is above and beyond!! Prices start at $1350 for SBC.
*The valve seat area is the most critical part of the flow path in a competition cylinder
h
Old 04-24-2011, 03:16 PM   #19
Chris Guthro
Re: Mid 13's?
Well it only cost 250 bucks for my freind to get his honda head ported polished, the same machinest told me it would only cost me 300 to bore my 350 .060 over, including the acid wash
Old 04-24-2011, 03:53 PM   #20
jrcaprai
Re: Mid 13's?
you do know you have to change springs, Rocker studs, and have them modified to accept larger springs too ???
read this, it is the definitive guide to vortecs
http://www.nastyz28.com/forum/showthread.php?t=56505
Old 04-24-2011, 04:32 PM   #21
Chris Guthro
Re: Mid 13's?
Didnt think that much was involved, how much power are vortecs able to make? and what size of a cam can they handle?
Old 04-24-2011, 04:46 PM   #22
PRattenbury
Re: Mid 13's?
Just buy a Fast Burn 385 from GM Performance. 385 ponies right out of the box.
PRattenbury is offline   Reply With Quote
Old 04-24-2011, 05:26 PM   #23
68GMCCustom
Re: Mid 13's?
he's gonna need more then that.....our 4600lb TBSS w/400hp LS2 only runs high 13's.
Kurt -
Old 04-24-2011, 05:29 PM   #24
PRattenbury
Re: Mid 13's?
Hmm. Okay, why not buy a RamJet 502 crate motor from GM Performance? 502 horses right out of the box!
Old 04-24-2011, 05:35 PM   #25
jrcaprai
Re: Mid 13's?
Well while were at it, how about a 572 ?
How much does a longbed Weigh ?
