Old 04-25-2011, 12:48 AM   #1
twotallswan
Question Good engine for 62 chevy truck?
Ok I have a feeling that I'm fixing to start a big fight, but I need some ideas. My truck is a 1962 short stepside and has a 283 that runs (or at least it did the last time I started it) and it still has the generator on it. Trying to decide on wether or not to leave it and just supe it up a little or do a transplant. If I do the transplant here's what I want to do the truck. I want to drive it around town and maybe take it to some car shows. I'm not really interested in racing it or creating some super custom. Probably gonna add some updates inside the cab and I'm going to put a tank under the bed.
Brass tacks-- I want to know what y'all think I should put in my truck. Open to any opinion as long as your polite about it.
1962 C10 Shortbed Stepside
1982 K5 Blazer
2011 Silverado LT Z71 4x4
2012 Malibu
A beautiful wife and 3 wonderful kids
TJ
twotallswan is offline   Reply With Quote
Old 04-25-2011, 01:51 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Good engine for 62 chevy truck?
Well you can’t really go wrong keeping the 283. Back when they were new it was about the most desirable engine to have, at least until the 327 came along. This would also keep it original. The trade off may be cost and convenience. It may be the same price or even less expensive to just buy a new 350 crate motor with a warranty. There’s a practical and financial reason the 350 is so popular.
I prefer the 350 myself. Often it can cost so much to rebuild the original heads it’s less expensive to buy new ones, and if the machinist isn’t top notch you can spend a lot of money and not get what you paid for. Also if the heads have been resurfaced too many times, it can result in intake manifold leakage problems that are hard to correct. The 350 Chevy crate motor in my 46 Ford traveled 300,000 miles in eight years with never a problem, and the one in my 60 GMC has about 20 years and 140k on it and is still going strong.
Old 04-25-2011, 08:36 AM   #3
Str8axle
Str8axle's Avatar
If there's nothing wrong with the 283, why replace it? Upgrade to an alternator and switch to electrinic ign. You can do a lot of things to a 283 and still keep it reliable.
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-25-2011, 11:48 AM   #4
steve'62
steve'62's Avatar
x2 on the thread, I also have a 62, but mine has a 235, I also want the same route as two tall.
http://www.automotix.net/engines/196...gmc_283lb.html
steve'62 is offline   Reply With Quote
Old 04-25-2011, 11:49 AM   #5
steve'62
steve'62's Avatar
I messed up the second link but they also have a 327 as well
Old 04-25-2011, 01:01 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I say run what you got, if there is something worong with it, rebuild the lower end and put some aluminum heads on it for better breathing. n sense in throwing a bunch of $ into a running play vehicle.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-25-2011, 03:09 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
If it ain't broke don't fix it. The fastest way to turn a good, usable truck into a cadaver is to pull the engine. I've done it before. Usually, once the engine is out, you get into a mode where you want to rebuild the suspension, paint the chassis, etc. The next you know, 5 years pass you by and it's still a cadaver in the garage. But, it has turned from a $1000 runner into a $10,000 cadaver.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-25-2011, 03:53 PM   #8
twotallswan
Thanx for all the advice.
1982 K5 Blazer
2012 Malibu
TJ
Old 04-25-2011, 04:53 PM   #9
scotts62
One day...
scotts62's Avatar
Have you been spying on me?? couldnt have said it better myself.
Scott
93 crew cab build
Project 62
Old 04-25-2011, 06:01 PM   #10
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Good engine for 62 chevy truck?
I agree Mark.
twotallswan,
Is your 283 the original factory?
Building a mild 283 is what I would do.
If you are not wanting a hause of a motor.
283:
Camel Hump heads..
650 Eldebrock or Holly Carb.
Nice Eldebrock or Holly intake
Dual pattern cam.
Long tube headers.
SLP Loud mouth/ Borla Singers/Magnaflow Magnapacks/Bassani/Cherry Bomb/2 or 1 chamber Flowmaster mufflers.
Dual Exhaust/X or H pipe
She would be one bad little screaming 283.
Come rolling up at a crusin or car show with that bump stick rat a tat tatting. . .
People will rubber neck and say, "Who dat in that '62?"
Come on lets check it out! You here it camming? Sick!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-25-2011, 06:28 PM   #11
twotallswan
According to the vin number, the truck should have been an inline 6 with three on the tree. When I got it, it had the 283 and had been converted to automatic. My fuel tank at the moment is a five gallon bucket. She needs a lot of work but she runs.
1982 K5 Blazer
2012 Malibu
TJ
Old 04-25-2011, 07:39 PM   #12
63sbssbbw
UCA63
63sbssbbw's Avatar
Either way I'd run the 283 with the upgrades mentioned
If it's got too many troubles, run a 350.
LOL pretty much what Mark and 1Bad said
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 04-25-2011, 09:25 PM   #13
1Bad62Pro/Street
Gimme the casting number off it and I'll tell you what year it is and what it came off of.
http://67-72chevytrucks.com/vboard/s...d.php?t=382583
Is the tranny a TH350, Powerglide?
Old 04-25-2011, 09:46 PM   #14
78 Chevyrado
If I'm at the car show and somebody's car has a 283 or 327 in it, I look at those cars 10x more than cars with 350's or even big blocks. I think either way as long as you don't get a 305 or 350, you'll get the looks. 350's just arent very special. 283's and 327s are though. and the number sounds cool.
78 Chevyrado is offline   Reply With Quote
Old 04-26-2011, 01:23 PM   #15
Indyuke
I say add ta 'nother five gal bucket "fuel cell" and yer well on yer way ta upgradin'.
Indyuke is offline   Reply With Quote
Old 04-26-2011, 01:33 PM   #16
markeb01
Senior Enthusiast
markeb01's Avatar
I agree completely. I wanted the looks of the 283/327 so I simply engineered a hidden smog valve installation so I could run the intake manifold with an oil fill pipe and closed valve covers. To further the effect the engine should run an early distributor and a short water pump.
Here's a link to how it was done should anybody want to modify a 350 to look older:
http://67-72chevytrucks.com/vboard/s...d.php?t=366853
Old 04-26-2011, 05:43 PM   #17
62 short step
62 short step's Avatar
I vote for the 283, im a little biased too though. Thats what im running.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 04-26-2011, 06:28 PM   #18
11echo
I'd vote for the 283 too! AND definetly up-grade the Ing. to HEI!!! And a set of headers! Good Luck!
11echo is offline   Reply With Quote
Old 04-26-2011, 10:53 PM   #19
62ShortStep
62ShortStep's Avatar
283.
But if you want to upgrade a bit...235.
62ShortStep is offline   Reply With Quote
Old 04-27-2011, 12:18 AM   #20
twotallswan
I really appreciate all the advice and everybody's sense of humor. This my first rebuild that I'm attempting. I have an 82 k5 but all I ever did was take the motor out because it had thrown a rod. It was given to me for 17th birthday by a doctor my mom worked for. It's missing alot of parts but the body is in good condition, the frame is straight and it still has the tranny and the four wheel drive. I bought the 62 from a guy I used to work with for 700 bucks. It runs but it had quite a bit of rust damage and needs new wood, a fuel tank, a tune up and the taillights rewired. Not to mention a new paint job and seats and interior and a stereo and........ Wait a minute. Anybody wanna but a couple of old junkers. Not really I could never sell them. Unless my wife leaves me and I need beer money.
1982 K5 Blazer
2012 Malibu
TJ
Old 04-27-2011, 02:29 AM   #21
Dino Driver
Dino Driver's Avatar
I had a 283 with the front horseshoe mount. I put a RV2 cam in and put a Edelbrock performance intake and carb with a TH350 tranny. It ran great with good torque. That truck is not the heavy, stock. It won't take much to get it to move. I pulled mine for a LS motor only because I'm a glutton for punishment. Stay with what you have!
Dino Driver is offline   Reply With Quote
Old 04-27-2011, 11:20 AM   #22
1Bad62Pro/Street
Originally Posted by 1Bad62Pro/Street View Post
I agree Mark.
twotallswan,
283:
Dual pattern cam.
Long tube headers.
Here is the perfect cam for that 283.
Nothing too wild like a Mother Thumper!
Camel Hump Head Combo
Chevrolet 291 327 Double/Camel Hump 1.94 Int 1.50Exh.
Camshaft Hydraulic Dual Pattern (Lift .443” Int., .465” Exh.)
http://www.jegs.com/webapp/wcs/store...+Dual+Pattern+
Camshaft Tips & Definitions
Life or Death Cam Knowledge:
http://www.hotrod.com/techarticles/c...ons/index.html
Dual Pattern Cam Idel= http://www.youtube.com/watch?v=onglWzXTveQ
Old 04-27-2011, 01:00 PM   #23
TheManInBlack
Originally Posted by 62ShortStep View Post
283.
Awesome
TheManInBlack is offline   Reply With Quote
Old 04-27-2011, 08:51 PM   #24
twotallswan
Man y'all make me feel dumb.
1982 K5 Blazer
2012 Malibu
TJ
Old 04-27-2011, 10:10 PM   #25
60n60Apache
Hey, GUys
I'm am fighting the same situration, but I have a 60 with a 1956 265 V8.
It came in it. It sound ok but can't drive it because of no exhaust.
Is the 265 a keeper?
60n60Apache is offline   Reply With Quote
1962, 283, engine, stepside
