Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-25-2011, 04:55 PM   #1
MadManAndrew
Anybody know these plugs?
The first picture is of what I pulled out. Second is of the one going in. First is a single plug with two rows of 10 pins. The adapter I need has to a male version of that plug. The second one is split into four parts with 5 pins each. My adapter would have to have a female version of this. Anybody know where I could pick one of these up?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 04-25-2011, 07:40 PM   #2
stich626
Re: Anybody know these plugs?
who makes the unit going in?
thats where I'd look for the plug/harness
stich626 is offline   Reply With Quote
Old 04-25-2011, 08:06 PM   #3
MadManAndrew
It's a pioneer, and I already found the plug on their site, but I wanna try and find an adapter.
Old 04-26-2011, 09:27 AM   #4
stich626
adapter from a X brand to pioneer ..
good luck.. the other one looks like it could be kenwood or clarion
I think the best was is going to be to cut the old plug out and rewire..
it's not that hard..
or at least cut of the plug and wire the new harness into it. if you trust you'll wire it right..
with wire'n I don't trust, if in doubt, redo
Old 04-26-2011, 09:36 AM   #5
MadManAndrew
The one I pulled out was a Jensen, thanks for the help. I wanted to try and keep the original wiring, that's why I didn't wanna just replace the plug.
Old 04-26-2011, 10:15 AM   #6
stich626
you can keep the org wire'n
if you can get the wire directions for that model
(what color wire is what)
bet the instrutions for the jensen is on line..
don't know if you mean the jensen wires as oeg wires or the trucks..
but I don't like wiring fires, and i'd undo the jensen plug harness and rewire your pioneer in . knowing all wires are connected correctly..
if you're sure of the work done when the jensen was installed , go online and get the wiring instructions for the jensen you pulled and match the wires to your new pioneer harness..
some even have the wiring instructions on the top of the unit..
most have
ground black
three + / 1) to dash lights 2) to battery (for memory) 3) ign switched
a blue wire to turn on amps it's to trigger the amp not power it..
some will have two blue a 2nd for power ant.
and some have a mute wire that go to a gps or cell phone iirc mine was brown or orange
then speaker leads and rca jacks..
look up your jensen and your pioneer and list on a paper what
color jensen goes to what color pioneer and then rewire it..
you'll find alot of the colors are going to be the same..
