Coolant temp sensor resistance?
I need a favor from some one if i could. I would like to see what the resistance is on a coolant temp sensor at about 75 degress. I am trying to get one for my EZ EFI kit that i dont have to use adapter for. The connector on my harness looks just like the factory ls connector. The kit uses all gm sensors so i am assuming they will be the same but i just want to make sure. Thanks.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
Has more rust than truck...
Re: Coolant temp sensor resistance?
2.56K ohms at 81deg. I hope someone will verify this as I had a hard time getting a good reading.
![]() Join Date: Nov 2007
Here is a graph of the current OE GM sensor resistance and the old one from the 60-66 trucks. Take care that the ohms are on a log scale. Looks like it is right at 2600 ohms at 81 deg. Looks like 75 deg. would be about 2800 ohms.
(2724 ohms according to the curve fit but it is a bit low at that end). TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Thanks guys. That really help now i can measure my sensor and see if it lines up. Realy dont want to have to get and adapter.
BMW & ASE Master Certified
for a 89-91 suburban
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
As it turns out the sensor they sent with the efi kit has exact same resistance as the factory lq4 sensor. Thanks for the info. Have it installed and it plugs in to my harness. So hope to have everything else on maybe next weekend or one after that.
