Old 05-07-2011, 12:25 AM   #1
ak_nut
Gas guage stuck on 3/4 tank
Hello guys..Today I bought a 87 burb and thought I was comming up seeing the tank was 3/4 full..Well I get it home and pull it around back to start the tinkering ritual and when completed the damn thing would start..Of course Im thinking it cant be out of gas...Well after checking the tank is empty..Threw some gas in and it started right up so the pump is good to go.
The first obvious thing to check would be the sending unit correct??
ak_nut is offline   Reply With Quote
Old 05-07-2011, 04:17 PM   #2
ak_nut
Re: Gas guage stuck on 3/4 tank
I probed the the red wire and the guage dropped down..So is it a bad ground??
Old 05-08-2011, 04:15 PM   #3
ak_nut
i fixed it
Old 05-08-2011, 10:07 PM   #4
Stoney
Farm Truck
Stoney's Avatar
How did you fix it?
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 05-09-2011, 01:46 AM   #5
ak_nut
Originally Posted by Stoney View Post
How did you fix it?
I yanked the unit out and opened up the little sending unit.I used sandpaper and cleaned the little ball/contact point that rides on the ohm board..The little tabs broke when I went to reassemble it so it it was welded back together...Then I soaked the whole unit in a mixture of vinigar and table salt for about 5 minutes. plugged it all up before it went back in the tank and it worked fine..Btw you can plug an ohm meter in to the plug of the sending unit and find out if the board is working correctly by moving the float up and down .
Old 05-09-2011, 11:23 PM   #6
68Timber
I know the pieces fit
68Timber's Avatar
Thanks for the follow up! I haven't had a fuel gauge problem yet, PTL.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
